Old 06-05-2007, 10:23 AM
The Dougfather The Dougfather is offline
Default Post Roll has stopped working???
Hi, just noticed after trying to do some punch-ins that my post roll has stopped working on both playback and record. The flags are at the top of the sequencer in the correct places, the pre roll works fine but the post roll refuses to play ball, any ideas.
Cheers
OSX 10.4.9, 7.1cs3, Macbook 2.16
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 06-05-2007, 11:36 AM
Default Re: Post Roll has stopped working???
Anybody?
iCON Photography
Old 06-05-2007, 12:40 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Check these steps... From Digi
Setting Pre- and Post-Roll
Pre- and post-roll times appear as flags in the
ruler that represents the Main Time Scale. When
pre- and post-roll are enabled, the flags are
green, otherwise they are gray.
Pre- and post-roll amounts can be entered in the
Transport window, set from a track’s playlist or
Timebase ruler, or by recalling a Memory Loca-
tion.
Setting Pre- and Post-Roll in the
Transport Window
Pre- and post-roll can be enabled and set in the
Transport window.
To set and enable the pre- and post-roll times in
the Transport window:
1 Select View > Transport > Expanded.
2 In the Transport window, click in the pre-roll
field.
3 Type in the pre-roll amount and press Forward
Slash (/) on the numeric keypad to enter the
value and automatically move to the post-roll
field.
4 Type in the post-roll amount and press Enter
to accept the new value.
5 To enable either pre- or post-roll, click the ap-
propriate button so it is highlighted."
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-05-2007, 12:43 PM
Thanks Park, it was in fact a momentary lapse of concentration, i haven't punched for while. I was forgetting to actually highlight the selection, i was just click straight on the session.
Duh
iCON Photography
Old 06-05-2007, 01:45 PM
Right. It has happened to me. That's why I listed the steps. It is all so easy to forget one.
Park
Park
Pre-Roll / Post-Roll - Not working! geelo Pro Tools 9 12 07-30-2016 12:02 PM
Pre and Post-Roll not working on D-Command Hanswurstlsepp ICON & C|24 3 11-08-2012 06:39 PM
Pre-roll/post-roll appears to be broken in PT10 anodecathode macOS 1 02-20-2012 01:33 PM
Pre/Post Roll not working! products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2010 07:47 AM
Auto Input not working with post-roll bublabs Pro Tools TDM Systems (Mac) 0 08-02-2006 05:14 PM
