Printing internal Dolby Atmos Renderer
Is it possible to print (not bounce) the output of the internal Dolby Atmos Renderer ? It seems that the "Renderer Out" (assigned in the Dolby Master Master Out) is kind of a hidden bus...so there's no way to route the Renderer outputs to another bus...or am I missing something ?
Any ideas ? Thanks, Christian |
Re: Printing internal Dolby Atmos Renderer
You can try this. Create a new 5.1 Audio Track. Set all individual you'd like to print on your track's Output to your newly created 5.1 Audio Track. Make sure your new 5.1 track has a selected supported Output. Record Enable your session then hit play. Let me know if it works on your end. Thanks!
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
The 5.1 and Binaural or stereo live Rerender is generally for metering or monitoring within Pro Tools. |
That's what I thought. So I'll continue using the external Renderer, create 7.1.4, 5.1 and Binaural Returns and be able to print those returns in pro tools.
Pro Tools 2023.12 Internal Dolby Atmos Renderer Questions and Setup Update | bolisound | Avid Pro Mixing General Discussion | 3 | 12-15-2023 07:51 PM |
Dolby Atmos Renderer v5.2 | dominicperry | Pro Tools | 4 | 12-15-2023 05:54 PM |
Dolby ATMOS Renderer | KeyplayerG | Post - Surround - Video | 20 | 08-22-2023 08:08 AM |
