Old 12-18-2023, 09:00 AM
inSync inSync is offline
Default Tempo change not working
I've set all audio tracks to tick based and elastic audio; rhythmic for drums, polyphonic for keys and guitars and monophonic for bass. I then try to set linear tempo change in the middle of a bar (from 66 to 46 BPM), but the sound is terrible, especially the bass.
Any suggestions?
Old 12-18-2023, 11:40 AM
_JJ_ _JJ_ is offline
Default Re: Tempo change not working
That's quite a dramatic musical challenge to try to make happen in post. Are you trying to make a sudden ritard at the end of a piece? Do you need this new super-slow tempo to continue for more than say 2-beats?
If you only need this to happen for a short moment you might be better off doing it all manually. Sustained bass notes are particularly handy to extend through editing if you zoom in and match the waveform... Just a thought.
2023 MacBook Pro 15,8 (M3 max)
Mac OS 14.4 (Sonoma)
PT 24.3.1.162 (Ultimate)
TB Native + Omni at home
Apogee Duet 3 on the road
Old 12-18-2023, 01:43 PM
Yes, I'm trying to do a quick ritard just before the last two bars. I will, as you suggested, do it manually. Good tip on the bass notes. Thanks a lot. You saved my day.
Old 12-18-2023, 03:22 PM
skylar_battles skylar_battles is offline
Easiest way is: set tracks to elastic audio, set tracks to ticks, and use tempo operations... Much more accurate this way too.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 12-18-2023, 04:06 PM
Thanks for the tip. Will try it.
Tempo change not working JPCPT120 Pro Tools 12 0 08-22-2021 05:43 PM
Tempo change not working! - Please, please help! diabolusinmusica Pro Tools 12 2 08-02-2015 04:50 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Ramping a Tempo Change (interpolation or discrete tempo points) edgarbc1 Tips & Tricks 3 02-18-2009 12:55 PM
