Old 10-12-2011, 07:12 AM
anackman's Avatar
anackman anackman is offline
Default Apple External Displays w/MacBook Pro?
Is there an issue with using firewire or USB inputs on an external Apple display hooked up to my MacBook pro?
The display contains several extra USB and Firewire inputs which makes it easier, since the MacBook pro really has limited amounts of inputs (only 1 firewire for example). Being able to use the display's inputs in conjunction would be great, but I'm wary of using them. Most of the time, Pro Tools stuff needs to be connected DIRECTLY to the computer and not any sort of hub or secondary device.
Is this the case? has anyone had success with using external display inputs?
MAC OS Ventura
Pro Tools 2024.3
2020 iMac 27" 3.2 Ghz i5, 64GB Ram
UA Apollo Rackmount Thunderbolt + Dangerous D-Box
2x Glyph Studio 2TB Raid SSD
Old 10-13-2011, 05:27 AM
anackman's Avatar
Default Re: Apple External Displays w/MacBook Pro?
any advice on this guys? appreciate it.
thanks.
MAC OS Ventura
Pro Tools 2024.3
Old 10-13-2011, 07:40 AM
chicken chicken is offline
thanks.
I use it like that, no problem. (iLok on USB connector display and secondary Firewire drive connected to the Apple cinema display).
New shoes always hurt.
Old 10-13-2011, 10:25 AM
Bielefeld Bielefeld is offline
I would be surprised if you were to have any issues with that seeing as how the new displays use the new thunderbolt port which is said to be wicked fast. However if you were to try it and run into problems let us know!
OS:
Mac OSX Maveriks 10.9
System:
2012 15" MacBook Pro With Retina Display
2.6 GHz i7 (Turboboost to 3.6 GHz), 8 GB RAM, 512 GB SDD
3 TB Seagate External USB 3.0 HDD.
500 GB Western Digital External Firewire HDD
Running:
Pro Tools 11.0.3
30" LCD displays: Apple vs. Dell jeremyroberts Post - Surround - Video 7 01-15-2007 11:39 AM
Apple cinema displays? banana boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-20-2004 04:47 AM
New Apple Cinema Displays DeVille Pro Tools TDM Systems (Mac) 10 07-02-2004 10:31 AM
Apple flat displays and Interference Soundworks UK Pro Tools TDM Systems (Mac) 3 06-24-2002 12:13 AM
About Appian Jeronimo2000 and TFT Apple displays Americo Pro Tools TDM Systems (Mac) 8 08-03-2001 03:22 AM
