MacBook Pro issues
HI All,
Does anyone else have this problem? I have a Mac Book Pro running Pro Tools 8 however I am regularly receiving -6101 errors asking me to increase the H/W buffer or reduce RTAS plugins. I get the error mostly when I use the templates (songwriter - guitarist) provided in PT8 and not much more. I change the xpand plugin to EZdrummer. I can't seem to record more than 50-60 seconds before the error occurs. I'm already on 1024 samples, 2 processors and 90%. Does anyone have similar specs and have the same problem? My specs are: Model Name: MacBook Pro 15" Model Identifier: MacBookPro2,2 Processor Name: Intel Core 2 Duo Processor Speed: 2.16 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 4 MB Memory: 2 GB Bus Speed: 667 MHz Sorry for the long post. Thanks for your help! Maars |
Re: MacBook Pro issues
Are you recording to a external firewire drive with a compatible firewire chipset?
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
I'm recording to an external firewire drive.
since you have 2 cores, go into playback engine and set it for 1 core, 85%.
Some plugins use non realtime code. In your case, setting your RTAS CPUs to 1 leaves your other core for any non realtime code and other processes. Note that this doesn't disable the other processor, it's just more efficient RTAS usage. Also, what other plugins do you have installed? 1 incompatible plugin (even if it's not used in the session) can cause lots of problems like what you're having.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
The other plugin that I'm using are the ones that came with PT8
Sansamp, D-Verb, EQ III, Eleven Free, Bombfactory compressor, JOMeek EQ, xpand and mini grand piano. |
try tracking to the internal drive. I do it all the time and never get payback errors. Either that or don't run as many plaugs while tracking.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod Terrarium HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2 (3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console |
I wouldn't record to the internal system drive unless I was just trying to test something. There's just too many things the OS is doing on that drive. I also agree with lowering the number of processor cores to one so that one is left free to handle non-realtime plugins.
Obsidian Dragon
Also upgrade to 4gB RAM. It is dirt cheap and will free up resources (system drive access).
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Digi 002 Macbook Pro Issues | Muzik8799 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-25-2010 06:55 PM |
MacBook Pro Issues | m_atrix13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-17-2009 01:55 PM |
iLok Issues on macbook and PC! HELP! | Kressack | Pro Tools M-Powered (Mac) | 1 | 05-12-2008 10:59 PM |
iLok Issues on macbook and PC! HELP! | Kressack | Pro Tools M-Powered (Mac) | 0 | 05-12-2008 06:03 PM |
Issues With New MacBook Pro...! | KingAce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-08-2008 04:52 PM |
