PT 7.3.1 M Powered very slow on each command..help
Hi Everyone
Hope there is someone to help me please. Setup is as follows Firewire410 with driver 1.8.1 approved with 10.4.0 OS G5 PowerPC 2GHz with 512MB Pro Tools 7.3.1 loaded. I have done the usual disables of Energy Saver,Spotlight,Dashboard etc When I load my PT session and select keyboard commands during edit the little spinning ball appears for about 20 sec then starts the command I have pressed. Each time the song plays and I select a new command it then stops playing, spins the ball and eventually starts again with the next command. The same happens in mix window when I add a new plugin. This is almost like a lag or something. CPU cant be the issue as it happens without any plugins added as well My record/playback partition has been correctly setup as OS journal extended. I must note that I have the exact same setup on my Powerbook G4 PowerPC and it works a dream, however because of processing power for RTAS plugins I need to move all to G5 asap. any help is appreciated regards Quinton |
Re: PT 7.3.1 M Powered very slow on each command..help
you need more RAM, remember, 512 is the minimum...I have 1.25GB in my G5 and still get the spinning ball so I know 512MB is going to get it...
Thanks Buctayla, appreciate the response
regards Quinton |
I am having the same problem. Have been using pro tools on pc desktop with 1 gig of ram with absolutely no problems. I just loaded all the same software (pt and plug-ins) on my Macbook with 512 mb ram, and I get nothing but little spinning balls. It is completely useless. Oh well, I guess I will have to invest in more ram.
Matt |
thank god for that!!! had same problem today on macbook. thought it might be ram so ordered 2 gig. looking forward to getting it now knowing it will solve my problem!
Digidesign Command 8 move super slow | royalmusicrecords | ProControl, Control|24, Command|8 | 0 | 12-10-2012 05:46 PM |
Command 8 will not control M-Powered | lucas.scott | ProControl, Control|24, Command|8 | 5 | 05-09-2010 12:52 PM |
Command 8 with M-Powered? | tha]-[acksaw | ProControl, Control|24, Command|8 | 6 | 02-20-2010 04:41 PM |
Command 8 not responding to PT M-Powered 7.4 | kavieix | ProControl, Control|24, Command|8 | 0 | 03-01-2009 09:42 PM |
M-Powered Slow Response | cwsand | Pro Tools M-Powered (Win) | 4 | 02-14-2006 10:09 AM |
