Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-24-2007, 06:04 AM
theQman theQman is offline
Default PT 7.3.1 M Powered very slow on each command..help
Hi Everyone
Hope there is someone to help me please. Setup is as follows
Firewire410 with driver 1.8.1 approved with 10.4.0 OS
G5 PowerPC 2GHz with 512MB
Pro Tools 7.3.1 loaded.
I have done the usual disables of Energy Saver,Spotlight,Dashboard etc
When I load my PT session and select keyboard commands during edit the little spinning ball appears for about 20 sec then starts the command I have pressed. Each time the song plays and I select a new command it then stops playing, spins the ball and eventually starts again with the next command. The same happens in mix window when I add a new plugin. This is almost like a lag or something. CPU cant be the issue as it happens without any plugins added as well
My record/playback partition has been correctly setup as OS journal extended.
I must note that I have the exact same setup on my Powerbook G4 PowerPC and it works a dream, however because of processing power for RTAS plugins I need to move all to G5 asap.
any help is appreciated
regards
Quinton
Old 01-24-2007, 07:56 AM
buctayla buctayla is offline
Default Re: PT 7.3.1 M Powered very slow on each command..help
you need more RAM, remember, 512 is the minimum...I have 1.25GB in my G5 and still get the spinning ball so I know 512MB is going to get it...
Old 01-25-2007, 02:06 AM
Thanks Buctayla, appreciate the response
regards
Quinton
Old 01-25-2007, 09:10 PM
bubbiesdod bubbiesdod is offline
I am having the same problem. Have been using pro tools on pc desktop with 1 gig of ram with absolutely no problems. I just loaded all the same software (pt and plug-ins) on my Macbook with 512 mb ram, and I get nothing but little spinning balls. It is completely useless. Oh well, I guess I will have to invest in more ram.
Matt
Old 01-30-2007, 02:18 PM
scuzzytim scuzzytim is offline
thank god for that!!! had same problem today on macbook. thought it might be ram so ordered 2 gig. looking forward to getting it now knowing it will solve my problem!
Digidesign Command 8 move super slow royalmusicrecords ProControl, Control|24, Command|8 0 12-10-2012 05:46 PM
Command 8 will not control M-Powered lucas.scott ProControl, Control|24, Command|8 5 05-09-2010 12:52 PM
Command 8 with M-Powered? tha]-[acksaw ProControl, Control|24, Command|8 6 02-20-2010 04:41 PM
Command 8 not responding to PT M-Powered 7.4 kavieix ProControl, Control|24, Command|8 0 03-01-2009 09:42 PM
M-Powered Slow Response cwsand Pro Tools M-Powered (Win) 4 02-14-2006 10:09 AM
