Re: EuCon 2023.11.0.121 Dropping Off
Thank you!
I just did that although it came up as Pro Tools 23Mac Is that ok you think?
Pro Tools Studio 2023.12.1, Mac Studio 2023 M2 Ultra, 64GB RAM, macOS Ventura 13.6.4 (22G513), UAD Apollo X8, Apollo x6 (2), UAD-2-Satellite-TB3-Octo, UAD-2-Satellite-TB3-Quad, Avid Dock w/ iPad Pro 12.9", Avid S1 (2) w/ iPad Air 10.9", Neumann KH 310 w/ KH750 Sub, Genelec 8320A, Adam Audio T7V w/ Sub8, G-Technology TB3 x 6 |
Yes
Thank you Eddie - I'll know within a day if there are any issues.
Appreciate it. Rick
It was too good to be true.
After bouncing a song and preparing to re-run it with changes I no longer have EuCon. In EuControl, Applications Pro Tools 23Mac is still listed.
Hi Eddie,
It just happened again and it seems to do this whenever I view another open app, in this case Music - I imported a bounced track.
One other observation is that it seems whenever this happens I lose my "Sign In" within Pro Tools; File, Sign In
umm...doesn't that need a network connection to sign in? Maybe thats the clue, you are losing the network. Do you have another Ethernet port to try?
I don't. This is a 2023 Mac Studio Ultra connecting to a Cisco SG-250-18 Switch. I can certainly move the port on the switch? I am using a CAT-8 cable to connect from the switch to the Mac and WiFi is disabled. I AM using DHCP and can try setting a manual IP if you think that would help. There is a pattern though I believe in that whenever I open an app out of PT such as Finder or Apple's Music and then go back to PT I lose this connection. I have a very clean environment and this computer is strictly for PT. I've gone through the recommended optimization, there's no AV to get in the way and no junk or trial software installed.
Can you post an image of the Applications tab in EuControl
Here you go and again...Thanks!
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta | theodd | Avid S1, S3, Dock and Control App | 14 | 10-19-2023 07:23 PM |
Eucon 2023.6 Crashes often when using PT 2023.3 | Selle Sellink | Pro Tools | 3 | 08-06-2023 02:29 AM |
Eucon S3, Dock and Avid Control dropping out | GLUltra | Avid S1, S3, Dock and Control App | 7 | 03-03-2022 03:58 PM |
Eucon is dropping features? | KeyplayerG | Artist Series | 3 | 08-20-2020 06:55 PM |
Eucon 3.3.2 keeps dropping connection with Nuendo 7 | KeyplayerG | Artist Series | 3 | 04-11-2016 08:58 AM |
