Old 02-17-2024, 03:27 PM
Mixmaster Rick Mixmaster Rick is offline
Default EuCon 2023.11.0.121 Dropping Off
All,
I'm running Pro Tools 2023.12.1 with EuCon 2023.11.0.121 and quite frequently my system will lose any connection between the two. I am left to "Restart EUCON Applications" until it happens again.
I am using an Avid Dock and two S1's.
Along with this behavior, and I'm using this as an example I use the UAD Oxford Limiter on an Aux track and I am unable to use some behavior of the Dock encoders to control certain parameters of this plugin.
In Pro Tools I highlight the Aux track then on my Dock select Inserts. From there I will select the UAD Oxford Limiter and the encoder for Input Gain works but Threshold, Attack and Release do not change with their corresponding encoders. This behavior is not limited to the Oxford Limiter. If there is a reason that this is by design can someone please explain it along with why I need to restart EuCon frequently?
Thank you,
Rick
Pro Tools Studio 2023.12.1, Mac Studio 2023 M2 Ultra, 64GB RAM, macOS Ventura 13.6.4 (22G513), UAD Apollo X8, Apollo x6 (2), UAD-2-Satellite-TB3-Octo, UAD-2-Satellite-TB3-Quad, Avid Dock w/ iPad Pro 12.9", Avid S1 (2) w/ iPad Air 10.9", Neumann KH 310 w/ KH750 Sub, Genelec 8320A, Adam Audio T7V w/ Sub8, G-Technology TB3 x 6
Old 02-18-2024, 05:16 AM
tope d's Avatar
tope d tope d is offline
Default Re: EuCon 2023.11.0.121 Dropping Off
Originally Posted by Mixmaster Rick View Post
All,
In Pro Tools I highlight the Aux track then on my Dock select Inserts. From there I will select the UAD Oxford Limiter and the encoder for Input Gain works but Threshold, Attach and Release do not change with their corresponding encoders. This behavior is not limited to the Oxford Limiter. If there is a reason that this is by design can someone please explain it along with why I need to restart EuCon frequently?
Thank you,
Rick
Hi Rick!
Checking on this. Will get back to you.
Thanks!
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 02-18-2024, 06:56 PM
EddieJones's Avatar
All,
Thank you,
Rick
We need to find out what is dropping. Is it a surface or a Tablet...look in the surfaces tab to see if it's one thing. When one thing drops the whole EUCON model has to rebuild to the new surface arrangement so it can look like its everything. Have you made sure the tablets/network is setup correctly, see here: https://avidtech.my.salesforce-sites...ontrol-Support
Old 02-19-2024, 09:18 AM
Hi Eddie!
Both S1's and the Dock appear in the My Surfaces section the last time I looked. I use all iPad's by the way. This has been going on throughout various iPadOS versions. All iPad's are currently at 17.3.1
The S1's use iPad Air 10.9"
The Dock uses iPad Pro 12.9"
I have attached the Help, About EuControl
I just checked the WiFi speeds on the iPad - all come in very string at 595Mbps over 63.5 Mbps
This behavior happens quite a bit. Thank you for helping.
Best,
Rick
Old 02-21-2024, 11:03 AM
EddieJones's Avatar
Hi Eddie!
Best,
Rick
Can you look in the Surfaces tab when this happens and see whats missing?
Old 02-21-2024, 11:14 AM
Hi - I have been. Everything is present. What else can I look for?
Old 02-21-2024, 11:18 AM
In fact it has been fine all afternoon but I stopped playback to answer this message and when I started up again I lost all faders on my S1's and Dock yet the My Surfaces shows perfectly
Old 02-21-2024, 11:20 AM
EddieJones's Avatar
Is PT in the Application filter list in EuControl?
Old 02-21-2024, 12:46 PM
Hi Eddie!
I'm unfamiliar with this but am assuming you mean in EuControl then the Applications Tab? No, PT is not listed but my password application, 1Password is
Thanks
Old 02-21-2024, 01:25 PM
EddieJones's Avatar
Hi Eddie!
Thanks
This could be your issue. Remove the password App and add PT to the list. You need to make sure you are focused on PT before pressing the + button
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 02:29 AM
Eucon S3, Dock and Avid Control dropping out GLUltra Avid S1, S3, Dock and Control App 7 03-03-2022 03:58 PM
Eucon is dropping features? KeyplayerG Artist Series 3 08-20-2020 06:55 PM
Eucon 3.3.2 keeps dropping connection with Nuendo 7 KeyplayerG Artist Series 3 04-11-2016 08:58 AM
