What's the fastest way to remove empty playlists?
The only thing I can do is individually right-click and select "delete" for each playlist track. I'm hoping that there is a more efficient way.
I also tried, "Delete Unused," but this also deletes the "non-empty" playlists, so it doesn't work that well for me. Last edited by SigFriedChicken; 03-05-2017 at 04:46 PM. Reason: trying to fix image size |
Re: What's the fastest way to remove empty playlists?
Sorry. I tried uploading a smaller version of the image, but it's still huge.
if you are only using one playlist, make it your main one, duplicate the track
and tell it to use main playlist only. then hide and de-activate the old track. |
But I would like the preserve the set of "good" alternate takes. I'm assuming (possibly incorrectly) that duplicating and only using the main playlist would not include these.
page 633 .. after searching for "delete unused playlists" .. Deleting a Playlist You can delete a playlist from a session entirely. However, since playlists require minimal disk space, you do not need to delete them to conserve storage. To delete one or more playlists from a track: 1 Click the track’s Playlist selector and choose Delete Unused. 2 Select the unassigned playlists you want to delete. Shift-click (Windows or Mac), Control- click (Windows), or Command-click (Mac) to select multiple playlists. 3 Click OK to delete the selected playlists. This operation cannot be undone. You can also delete playlists in Playlists view. Right-click the Playlist Name on a lane or in the Track List and choose Delete. When deleting a track from a session, you have the option of deleting or keeping its playlists, so they can be used on other tracks.
Prior to 12.6, you could switch the track view from playlist view to waveform view and then back to playlist view and all unpopulated playlist lanes would be removed and only from that one track. Alternate playlist lanes would be kept if there were any clips on them but empty/unpopulated lanes would be deleted.
In recent versions of PT12, this has not been working the way it used to. I have created a support ticket about this but have not heard back. SigFriedChicken, consider starting a support ticket also. If enough people complain, it may get addressed. This feature used to be there, all Avid has to do is restore it back to how it was pre 12.6!
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
I kind of found the "invisible if empty" playlists thing a bit annoying on occasion, as you couldn't move stuff onto pre-existing (but empty) playlists in playlist view as they simply weren't showing. But it's not a biggie either way for me so happy to vote up if general consensus is to go back to prior behaviour.
I am aware of this option, as my original post indicates. The problem is that you can't remove the playlists until you switch to waveform view, which hides the playlists from you, making it very difficult to know which ones to remove. |
I do recall, in 12.5.x, that toggling to waveform, and back, would remove the empty playlists. I guess that explains why this issue never occurred to me before now.
A way to automatically remove empty audio clips? | Rockman413 | Pro Tools 12 | 10 | 11-22-2016 01:58 AM |
how to display empty playlists | bolooki | Pro Tools 12 | 2 | 11-01-2016 02:49 PM |
can you remove an empty channel from the surface of a VENUE profile console? | marcnyc | VENUE Live Sound Systems | 5 | 06-25-2011 08:53 PM |
Delete "empty" playlists? | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-15-2009 08:06 PM |
FEATURE REQUEST: Delete Empty Playlists | ilovemyssl | Pro Tools TDM Systems (Mac) | 0 | 10-16-2006 03:44 AM |
