Old 09-06-2011, 10:53 AM
nd nd is offline
Default Using a subwoofer with X-mon in surround AND stereo
Hey fullas!
Planning to get my X-mon system with my D-command working to it's full capabilities. After re-reading the manual and searching the net I can't come across any information about this....
I want to use the "main inputs" and "main speaker outputs" of X-mon with a 5.1 surround setup, with it also being capable of stereo without a hitch.
My trouble is that 90% of my work is in stereo, but if I have my sub receiving it's signal from the X-mon "main speaker output 8 (LFE)" as advised in the manual, how the heck can I utilise the sub with my stereo mixes?
My previous setup was running the stereo outs into the sub and then the hi-pass outs from the sub to the main stereo monitors and for the rare 5.1 mix, I'd change the cabling.
Thanks!
Old 09-20-2011, 11:54 AM
budster budster is offline
Default Re: Using a subwoofer with X-mon in surround AND stereo
You would need a bass management system.
Buddy
Old 09-27-2011, 10:38 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Thanks!
That will still be the case .... Sub for 5.1 or any multi format setup is a dedicated signal. In the case of stereo it is not. Hence the need for a dedicated physical connection for mutiformat as well.
Bring it all onto a patch and connect from change wiring when needed could make things easier ?
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer Ale Pro Tools 10 3 08-14-2012 09:05 AM
Surround Mixing / Stereo monitoring with Soundcode Stereo Meads Post - Surround - Video 6 01-04-2011 04:52 AM
Stereo to 5.1 Surround jim2step General Discussion 5 04-23-2009 03:59 PM
Connecting a Subwoofer to a stereo setup on a C24 Echo studios ICON & C|24 3 10-05-2007 09:40 PM
Surround Mix-Stereo to 5.1 tbird Post - Surround - Video 6 09-16-2003 06:56 AM
