Old 02-28-2016, 04:35 AM
nd nd is offline
Default How to monitor through laptop speakers
Hey guys!
I'm using PT12 on a MacBook Air, with an Apollo interface.
I'd like to set up the option to check my mixes through the laptop speakers.
I'm using a hardware insert on my master fader, so it's not as simple as changing the playback engine (that will disable my in/out).
I'm guessing somehow the aggregate setup may be able to do this? I had a play but couldn't figure it out...
Old 02-28-2016, 04:43 AM
Drew Mazurek's Avatar
Default Re: How to monitor through laptop speakers
Originally Posted by nd View Post
Hey guys!
offline bounce, listen in iTunes.
Simple, easy, less likely to cause issues.
www.drewmazurek.com
Old 02-28-2016, 07:02 AM
Hey guys!
You can try, aggregate IO is frequently problematic, I have no idea if it works well with your interface.
create the aggregate in Audio/MIDI setup, normally you would use the Pro Tools Aggregate device that is already there. Aggregate your interface and built-in output. Set the interface as the clock source and check correct drift for built-in output.
Now select that aggregate as the playback engine. you will likely need to go in and edit the IO outputs to add or at least nicely name the Built-in output stereo pair. Once you do that you can route to that path to listen on those speakers.
It may or may not be worth doing all that, depends on how you want to work. Drew's suggestion may be better. Other folks may route out S/PDIF or analog from the interface back into the Mac.
Old 02-28-2016, 08:38 AM
JuanPC JuanPC is offline
Some Swedish House Mafia songs sound amazing on MacBookPro speakers...
But.. In a real club/large sound systems... Not so good.
If you master too hot... Will only sound good in tiny speakers.
Option A) make a mix that works in both systems. Sacrifice things in both.
Option B) make a mix that sounds better in tiny speakers, sacrifice large systems.
Option C) make a mix that sounds better in large speakers, sacrifice small speakers.
Old 02-28-2016, 09:02 AM
Glenjb Glenjb is offline
Or just click on the bounced file in a finder window and hit spacebar, no need for iTunes
Old 02-28-2016, 09:20 AM
That works as well, but the thing I like about checking with iTunes is toggling Apple's "Sound Enhance" and "Sound Check" on/off to hear their impact. This is important since all Macs come with these features enabled (best I remember)
www.drewmazurek.com
Old 02-28-2016, 06:31 PM
nd nd is offline
Yeah, I already check with this method...but I'm hoping to be able to just switch on the fly, while I'm mixing, so I don't have to bounce and then make changes and bounce again. It's real time bouncing for me, because of the hardware insert.
Old 02-28-2016, 06:35 PM
nd nd is offline
There's something about the tiny speaker that reveals the lower mid range for me. Even after checking in my Auratone knockoff, I appreciate what the laptop speaker reveals, no matter what speakers I want it to sound best in.
Old 02-28-2016, 06:37 PM
nd nd is offline
I don't have the line-in on my Macbook Air.
I'm gonna have to try more with the aggregate and see if it will work....
Old 02-28-2016, 07:15 PM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
You can go to Playback Engine, chose simply the Built-In Output of your Mac, I do That to work out of house with Heaphones......
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Monitor Through built in Laptop Speakers? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-16-2009 11:57 AM
Help me! Need playback through laptop speakers cclarkaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-24-2008 01:05 AM
Editing speakers for a Laptop KJVMBird 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-03-2006 12:40 AM
Used monitor speakers AncientMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2005 06:59 PM
001 monitor thru Mac speakers? Abby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-17-2002 02:26 PM
