Old 03-14-2014, 04:18 PM
davegibbon davegibbon is offline
Default CPU overload, hot computer and kernel_task
Hey there,
I just upgraded to Mavericks 10.9.2, PT11.1.2 and the newest Avid driver for my 003R. I'm on a mid-2010 MacBook Pro i5.
It's been awful. As soon as PT loads, Activity Monitor shows a thread called 'kernel_task' that chews up CPU like crazy. Computer gets hot, fans go crazy and the computer grinds to a halt. I can't even record/playback one track of audio in PT.
I've seen threads from people with the same problem both here and on other audio discussion boards. No solutions but people reporting exactly the same thing.
The thing is, I can't find anything beyond January 2014. Has this stopped being an issue? Or have people given up and gone back to PT10 with ML or something?
Any advice/venting would be appreciated.
Old 03-14-2014, 04:38 PM
Default Re: CPU overload, hot computer and kernel_task
I had my suspicions that the problem was with the Avid driver but now I'm sure.
I installed a driver for an old MOTU interface that was lying around, started up PT and all is well. Kernel_task is sitting around 7-8%, no errors on record/playback.
This will let me work this weekend but Avid, c'mon...
Old 03-14-2014, 04:53 PM
propower propower is offline
Is it this?
http://duc.avid.com/showthread.php?t=349742
If not - why not describe all the details. Does it happen with just AVID stock plugins?
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 03-14-2014, 07:18 PM
Looking at that thread, I initially thought it was the same thing but looking at the video it not quite the same.
I don't even have to record, play anything back or insert a plug to get the kernel_task thread going over 120% CPU. I haven't installed any third party plugs on this system yet. It's a fresh OS, fresh PT download and a fresh driver download.
I opened Ableton Live, same problem. It's like as soon as the machine addresses the 003R, kernel_task goes crazy.
I've seen others with the problem but I just haven't seen any recent posts about it.
Old 07-16-2014, 11:29 AM
domavila domavila is offline
I have the exact same problem in PT 10. It is the driver for sure and doesn't matter if you are using pro tools 10 or 11. My CPU kernel task goes to 70% as soon as I turn on my 002 and goes back down to 3-7% when i turn off my 002 or unplug the firewire cable. This is a serious problem because it heats up my computer and I can't even use more than a couple plug ins without my computer grinding to a halt.
Please someone at avid find a solution for this problem. My computer is overheating and I can't produce without turning off my 002 and using headphones.
This is completely ridiculous and inexcusable for Avid. We as Avid/Pro tools users constantly pay for upgrades and for a driver to overheat my computer which is practically rendered useless do to the CPU kernel task spike is inexcusable.
Today I am going to try a firewire to thunderbolt adapter to see if that helps but I find it highly unlikely. This is something avid needs to fix and fix soon!!
Old 06-01-2016, 09:40 PM
Ed Douglas's Avatar
Ed Douglas Ed Douglas is offline
Having this issue intermittently in PTHD12.5... so not much progress then?
This bug first reared it's head for me when I was premixing from my portable system in a $600/hr studio and caused me a completely wasted day!
Grrrr.
E>
Neotech Concepts
http://www.imdb.com/name/nm0235036/
! sonic gymnastics for the illusionary arts !
2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch,
EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB
kernel_task takes up all CPU when Pro Tools is playing back Cribs macOS 5 09-04-2014 01:32 PM
CPU Overload obiwan177 Tips & Tricks 4 08-18-2009 12:19 PM
CPU Overload Help? Abby B Pro Tools M-Powered (Mac) 0 03-09-2009 02:44 PM
CPU OVERLOAD Friend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-11-2007 03:56 PM
question : can i copy/paste all my computer hard/soft to other computer . for a gig. sandman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-10-2001 08:38 PM
