DAE 35 Error from FW 800 drive
On a New 2.2 Mac Book Pro with PT 9.03 and Snow Leopard 10.6.7. 4 Gigs of Ram
I have a session that is 1.6 Gigs in size that is on a Freecom 7200 RPM FW 800 drive. It has only five stereo tracks and I am not running any plugs at the moment. Spinning ball for a few minutes and then DAE 35 Error shows up. When I copied the same session to my Mac Pro HD, it runs smoothly with minimal Disk Usage and System usage. Any ideas?? Thanks Paul
International Award Winning Arabic Fusion www.ajmusiconline.com --------------- 2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8 3xVisionDaw,NI Komplete,Yamaha 01V/96 |
Re: DAE 35 Error from FW 800 drive
What interface are you using (FW interface?), how is the interface and disk drive connected in relation to each other?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
I forgot to mention I am using this on the road so only using built in audio.
You can try formatting it with zeros. It might find some bad blocks. You might also want to check out drive genius. |
I would agree with the previous post, if nothing else but the drive is on the FW port, I would suspect the drive.
It is a brand new drive, so maybe something wrong with it. Disk utility did say it had a problem, but I deleted what few files were on it and successfully repaired it.
Disk Genius will run a sector block scan and write data on bad blocks. IT takes some time, but it is worth it. New doesn't mean it will be fine. The fast format isn't a secure thing. |
Hmm....the FREECOM drive seems to play back "The Numbers Game" demo in logic with no problem.
40 tracks of Audio and soft synths. Could there be some other problem here?
So don't say I didn't warn you. |
DAE error with new firewire drive | BC_Nash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-14-2011 06:56 AM |
'No disk in drive' error... | xeetstreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-04-2004 07:33 AM |
Firewire drive error???? 104 error? | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-21-2003 09:43 AM |
HELP!!!The drive reported an ERROR... Sense key = HARDWARE error | Alécio Costa | Pro Tools TDM Systems (Mac) | 6 | 03-03-2002 12:23 AM |
Drive error | Nick Le Mon | Pro Tools TDM Systems (Mac) | 4 | 12-28-2001 08:16 AM |
