Old 05-27-2014, 08:13 AM
cwhite771 cwhite771 is offline
Default Re: PT10.3.8/PT11.1.1 launch issues...
Back again! Just an update to my issues from my original post at the top here.
So, I just updated to 10.3.9 and 11.1.3.
With the update to 10.3.9, all seems good now. No weird launching of the updater app, errors, or warnings anymore.
However, still having the same issues as previous with PT11... "You don't have appropriate access privileges (1)" error happens immediately on launch when "initializing databases". It's obviously some kind of permissions issue. I feel that if I knew where PT11 was accessing this, I could probably change the permissions and it would be fine.
I've just been continuing to use PT10 to get work done since I can't really afford to spend the time (that I don't have anyway) wiping my machine and re-installing everything. It would be nice to be able to use PT11 finally though. I guess I should prob bite the bullet and contact support.
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff.
Old 05-27-2014, 07:08 PM
Chief Technician Chief Technician is offline
Post Re: PT10.3.8/PT11.1.1 launch issues...
/Library/Application Support/Avid/Pro Tools
That directory, and the ones contained within, should be owned by root with a group of admin. Root, admin, and everybody should have read, write, and execute privileges.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 06-02-2014, 09:29 AM
Thanks for the reply, Chief Technician. I checked the permissions and they were read/write for all the available users (cwhite (me.. admin user), system, admin, and everyone). Still wasn't getting past the DB initialize. So, I discovered the Workspace.wksp file in /Users/shared/Pro Tools/. I moved that out to the desktop, launched PT11, and bingo. It opened.
However, it seems to be launching the SoftwareUpdater again as PT10 used to, showing the "You do not have appropriate access privileges (1)" error. I can seemingly run PT11 without issue now... but it would be nice to not have the updater problem and know that it's all working as it should.
c
Old 06-02-2014, 03:00 PM
Question Re: PT10.3.8/PT11.1.1 launch issues...
Thanks for sharing the tip.
I haven't had issues with the Software Updater. Which version's software updater is giving you grief?
Old 06-26-2014, 07:08 PM
Craig Stuart Garfinkle Craig Stuart Garfinkle is offline
I can't believe it. I was having the same problem launching PT 11. Changing the name of my hard drive allowed PT 11 to open.
This is messed up!
Old 06-27-2014, 05:45 AM
Mr.O Mr.O is offline
I have similar problems here:
installed PT 10HD and PT 11 HD on a fresh OSX 10.8.5,
nothing else installed
then the 2 Avid Air instrument collection bundles, and...
PT10 crashes at startup
unfortunately the licence, the Avid Support Centre sent to me,
does not work - the old 9th licence is surrendered, if you update !!!!!
No working Protools - wow
Mr.O
Old 06-27-2014, 06:30 AM
Could you please post the data from the crashed thread? Crash logs can be found in the Console.app (/Applications/Utilities).
PT11 launch time mesaone Pro Tools 11 23 04-28-2015 10:09 PM
PT11 asks for activation at launch sanjaydas7 Pro Tools 11 17 02-20-2015 02:44 PM
Co-Install PT11/10.3.8 - Can't launch PT10 - Help kentuckyben macOS 2 01-07-2014 02:18 PM
How was PT10 a transition to PT11 and AAX? WinTaper Pro Tools 11 38 07-28-2013 07:04 AM
Buy PT10 now - what about PT11? starburst Pro Tools 10 8 03-15-2013 11:09 AM
