Old 07-05-2011, 07:29 AM
dubaifox dubaifox is offline
Default DAE 35 Error from FW 800 drive
On a New 2.2 Mac Book Pro with PT 9.03 and Snow Leopard 10.6.7. 4 Gigs of Ram
I have a session that is 1.6 Gigs in size that is on a Freecom 7200 RPM FW 800 drive.
It has only five stereo tracks and I am not running any plugs at the moment. Spinning ball for a few minutes and then DAE 35 Error shows up.
When I copied the same session to my Mac Pro HD, it runs smoothly with minimal Disk Usage and System usage. Any ideas??
Thanks
Paul
International Award Winning Arabic Fusion
www.ajmusiconline.com
2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8
3xVisionDaw,NI Komplete,Yamaha 01V/96
Old 07-05-2011, 07:56 AM
bradch00 bradch00 is offline
Default Re: DAE 35 Error from FW 800 drive
What interface are you using (FW interface?), how is the interface and disk drive connected in relation to each other?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 07-05-2011, 08:27 AM
I forgot to mention I am using this on the road so only using built in audio.
Old 07-05-2011, 08:40 AM
lexaudio lexaudio is offline
Thanks
Paul
Your drive is possibly going bad. Backup everything to another drive.
You can try formatting it with zeros. It might find some bad blocks.
You might also want to check out drive genius.
Old 07-05-2011, 08:46 AM
I would agree with the previous post, if nothing else but the drive is on the FW port, I would suspect the drive.
Old 07-05-2011, 08:57 AM
Thanks for the responses.
It is a brand new drive, so maybe something wrong with it.
Disk utility did say it had a problem, but I deleted what few files were on it and successfully repaired it.
Old 07-05-2011, 09:06 AM
The only way to know for sure if a drive is good, new or not, is to do a full zero format.
Disk Genius will run a sector block scan and write data on bad blocks.
IT takes some time, but it is worth it. New doesn't mean it will be fine.
The fast format isn't a secure thing.
Old 07-07-2011, 12:30 AM
Hmm....the FREECOM drive seems to play back "The Numbers Game" demo in logic with no problem.
40 tracks of Audio and soft synths.
Could there be some other problem here?
Old 07-07-2011, 07:40 AM
Doesn't matter. Playing the other daw game is going to cost you your data.
So don't say I didn't warn you.
[IMG] code is Off
DAE error with new firewire drive BC_Nash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-14-2011 06:56 AM
'No disk in drive' error... xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-04-2004 07:33 AM
Firewire drive error???? 104 error? Burton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-21-2003 09:43 AM
HELP!!!The drive reported an ERROR... Sense key = HARDWARE error Alécio Costa Pro Tools TDM Systems (Mac) 6 03-03-2002 12:23 AM
Drive error Nick Le Mon Pro Tools TDM Systems (Mac) 4 12-28-2001 08:16 AM
