anyway to pass 96k through tdm?
I have a gig next month for nasa (yes, it actually IS rocket science) they want me to record the space shuttle launch at 24/96, then do a kickass surround mix for a film they are making. aquisition is not a problem but editing and mixing on my protools won't be possible. Is there anyway to use aux ins and the TDM mixer with 24/96 sources (instead of from the disk)? I doubt it, but I thought i'd ask.
so next question: does anyone know of a cheapish 24/96 surround mixing capable rig I could buy or rent? Layla, Motu, any of this low endy stuff that seems to have some high endy features? Appreciate any advice. (mix +) Tom |
Re: anyway to pass 96k through tdm?
Although I have not tried to do this, it is in fact possible to record and edit (at least 2 track record and edit) 96k on protools. You will need a 96k converter AD/DA that supports the 2 wire standard such as the psx-100. Follow this link for the notes from apogee: http://www.apogeedigital.com/pdf/appnotes/appnote17.pdf
Good Luck! By the way, MOTU Digital Performer will handle 96k so long as you are using one of their 96k I/O boxes. You should be able to ourchase one box and the software and do the mix. The price should be under $2000 for the basic setup. [ July 29, 2001: Message edited by: Ask Otis ] |
... or just do everything 24/48k and convert up when finished. You might get better results than trying to use gear your not familiar with and a worse mixing environment. You could also just run some nice analogue gear on your 5.1 buss and record it at 96k after mixing at 48k...
my very opinionated $00.02!!! [img]images/icons/grin.gif[/img] |
thanks for the responses. i will look into the motu solution. The client is making a hi-def product and is being pretty freaky about 96k all the way through. i wouldn't want to try to slide anything by them, or admit that my hi-tech studio isn't up to the job. digi...take note
I agree with Otis. I would go with the bit-splitting option on an Apogee PSX-100.
Jim |
Probably not a good idea to try and pull a fast one on Nasa [img]images/icons/grin.gif[/img]
Wouldn't that mean you'd need a PSX100 for each pair of channels? [img]images/icons/confused.gif[/img] Meaning 3 PSX100s for surround? (5.1) and using 2x the ammount of channels in PT, and not being able to use plug-ins at all???? BTW: Logic also does 96k, and I'd MUCH prefer that to DP. |
Man that sounds like a kill job. Curious though, What mics and mic pres will you be using for the job. Lots and Lots of spl.
KBP |
In the past I've miced everything up like this (and had some great results):
- A PZM in the cockpit (left quite low in the mix with a ton of reverb) - A 'direct in' feed from the control tower - And, 3 M149s close miced under the rockets [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/wink.gif[/img] |
Tom,
Try to convince NASA to let you record the sound with analog gear and transfer it to 24/96 later. You can easily rent the equipment and are sure to get the BEST results... |
Maybe just ask Digi very nicely to get a 24/96 version of their hardware & software early. [img]images/icons/wink.gif[/img]
High pass and low pass filter for distorted guitars? | adamqlw | Eleven Rack | 13 | 09-30-2011 10:35 AM |
> Aux does not pass audio | Howardk | Pro Tools TDM Systems (Mac) | 4 | 04-20-2007 07:53 AM |
And so it has come to pass.... | Datus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-20-2003 05:21 PM |
hi-pass EQ | sandman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-13-2001 04:54 PM |
anyway to pass 96k through tdm? | tomcat | Tips & Tricks | 0 | 07-28-2001 11:14 PM |
