#251
Re: HEAT (Harmonically enhanced Algorithm Technology)
--- RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1, MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1 3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate |
#252
Hi.I have been buy HEAT plugin.Can tell me any one please,is normally to work on the same time with HEAT plugin and Dangerous 2buss summing amplifier with +6db button swiched or 0db swiched.
Please help me. Thanks |
#253
_
rickkrizman.com Last edited by RKrizman; 02-18-2011 at 11:54 PM. Reason: premature ejaculation |
#254
Is it permitted to cross-post to other forums? Here are some comparison files I put up as Gearslutz.
http://www.gearslutz.com/board/gear-...son-files.html -R
rickkrizman.com |
#255
I've been using it for nearly 3 weeks now and it's made me hold on to my TDM rig! I picked up HD2 last August for a bargain price, and then with PT9 released I was considering the move to a native solution given that I only ever track 1 or 2 inputs at a time.
However, HEAT has messed up that plan. I have been using the SSL Bus Compresser as my mix glue for years, but using HEAT I can't use the SSL - it seems to take away the rich velvet and sparkle that HEAT adds to the mix. My mastering engineer even had it engaged (albeit very subtly) on a recent 2 channel mastering session we did. I can only describe it as adding 'life' to a mix. I'm all for the 'switch it on and it sounds better' ethos. SPL Vitalizer was the last product I got that did that for me. If only it were a bit cheaper in europe |
#256
it looks like a plugin on each channel.
which is fine to me, but it wold be soooo much better to be able to change it on each channel. I am using this for a mastering session now, so the disadvantage is clear. The solution is automating the main heat control so I can still alter the settings for each track oh no wait this can't be done either. I DONT UNDERSTAND why these audiopeople keep thinking like it's 1960. duh, we are doing analog emulation, so we though automation or track by track adjustments couldn't be done on analog so let's leave it out. clearly it was not meant for the way I use it, but that does not mean I don't want to, or any one else for that matter. the reason why I am so mad, is that the thing sounds AMAZING!!! otherwise I would not have posted this,... so please DIGI listen to me and take your timemachine from 1960 to 2011 thanks, Mark P.S a level trim would be nice to have to, so it's easier to compare a track to the non-heat version |
#257
I downloaded the demo and have Heat on all the tracks but not the master control. Why would that be?
#258
Down the bottom right hand side of the mix window you have to click the arrow to reveal the HEAT master controls.
https://www.glasshousestudios.com.au Mac Studio M1 Max 32 GB ram macOS Ventura 13.1 24 core Metal 3 GPU Avid MTRX Studio Pro Tools Ultimate 2023.12 HDX card AVID TB3 1 slot PCie Chassis |
#259
Thats it.
Thank you very much. Larry |
#260
Glad I could help Larry - you're gonna luv HEAT.
Does comping to a Heat enabled track print the Heat? | joshdrucker | macOS | 0 | 03-12-2014 10:17 PM |
9.0.2 crashes when setting X-Form algorithm | A Chapman | macOS | 3 | 03-22-2011 08:38 AM |
Melodyne algorithm unhappiness thread | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-26-2009 02:28 PM |
Rhythmic algorithm | Steve MacMillan | Pro Tools TDM Systems (Mac) | 3 | 11-28-2007 10:44 AM |
positional scrubbing algorithm? | KingTor | Pro Tools TDM Systems (Mac) | 0 | 06-05-2000 01:04 PM |
