loop playback intermittent
Hey folks -
Have any of you had the problem of playback looping only working intermittently? I always have the option checked, but quite often the region I select just refuses to loop. It reaches the end of the phrase and then just stops. Then, seemingly inexplicably and within the same session sitting, it will start to work again ... and then stop. Does anyone have any insight into this? Craig |
Re: loop playback intermittent
Loop Playback will not work if you are in Quickpunch mode and have a track armed.
…and if the region to be looped is less than 500ms-long.
IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Automation playback intermittent | rhumphries | Post - Surround - Video | 6 | 06-21-2011 12:02 PM |
Intermittent playback | mcfly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-14-2008 03:53 AM |
Loop Record and Loop Playback will not engage? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2008 06:03 PM |
Intermittent Playback through M-Box 2 mini | Sadie Tango | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-25-2006 05:46 PM |
