Old 12-31-2009, 08:23 PM
mike8338 mike8338 is offline
Question pro tools issues & error messages
hi im new with the pro tools i was giving for christmas the mbox 2 factory bundles set etc etc....i linked my protools 8/8.0.1 (updated it) mbox 2 etc etc to my toshiba satellite a105-s101 laptop...
Manufacturer : Toshiba
Mainboard : ATI SB450
Chipset : ATI RS400/RC400/RC410
Processor : Intel Celeron M 380 @ 1600 MHz
Physical Memory : 2048 MB (2 x 1024 DDR2-SDRAM )
Video Card : ATI RADEON XPRESS 200M Series
Hard Disk : FUJITSU (60 GB)
DVD-Rom Drive : TSSTcorp CDW/DVD TS-L462C
Monitor Type : 20 inches
Network Card : AR5005G 802.11a/b/g Wireless Network Adapter
Network Card : RTL8139/810x Fast Ethernet Adapter
Operating System : Microsoft Windows XP Home Edition 5.01.2600 Service Pack 3
DirectX : Version 9.0c
my pro tools loads up it does all that...i can and did record vocals dubs and ad libs but when i play it back i get ..
error message -9129: audio processing is conflicting with other cpu task if this occurs often reducing the "h/w buffer size" in the playback engine dialog may help prevent this problem..... but when i do that then i get
error message -9092: the operating system held off interuppts for too long if this occurs often try increasing the "h/w buffer size" in the playback engine dialog..
i believe my labtop is not fully compatiable or i dont know what the issue is....also protools allows me to pull in a track off a cd to use...but when i try to import a track from off my desktop my protools closes it's self and when i click the icon it saids pro tools was shut down wrong please reboot the computer to be able to run pro tools...
can some one please help me out...i would really aperciate it..
im new to this thread so if u can e-mail me some solutions would be [email protected] if not you can just respond to this thread..i will check lata
Old 12-31-2009, 08:39 PM
Creager Creager is offline
Default Re: pro tools issues & error messages
1: Read this
2: Take down your email address. It's only beneficial that you get answers in an open forum. Nothing like following bad advice you got in an email. On an open forum, bad theories usually get called out.
3: (A total guess) It sounds like you're running on a single hard drive. To run Pro Tools, you need at least 2.
HD 1: OS, apps and software
HD 2: a firewire external or a 2nd internal physical drive
(USB is not supported, a different partition of the main drive doesn't help)
HD 3: back-up and storage (something you're going to want)
Good luck, and welcome to PT.
- Formally trained audio novice.
Pro Tools 2020.10
iMac (21.5-inch, Late 2015)
OSX 10.14.6 (Mojave)
2.8 GHz Intel Core i5
16 GB 1867 MHz DDR3
Digi 003 Rack
Presonus Firestudio
Motu 828mkii
Pro tools gives me error messages Protoolsdub Pro Tools M-Powered (Win) 5 12-31-2012 01:03 PM
Pro Tools throwing cpu error messages elvolutionstudios macOS 7 06-28-2011 01:42 PM
Many different error messages, Pro Tools aborting or unable to click messages off riffmachine Pro Tools M-Powered (Win) 5 10-05-2010 04:15 AM
Pro Tools LE 7.4 complete shutdown during operation without error-messages Soundviking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2009 08:02 AM
Pro Tools M Powered Error Messages jomeo69 Pro Tools M-Powered (Mac) 1 01-30-2007 08:54 AM
