Old 02-15-2015, 10:47 AM
JonesH JonesH is offline
Default Cleaning up multiple tracks at the same time?
I'm working on an orchestral recording and there are a few noises here and there. When I work in Sequoia I can use the built in Spectral Cleaning to find and kill a noise on one track and it then applies the same process to the other tracks. Is there really no better solution than to manually RX every track in a 24 channel recording?
I just wanna do engineering...
(as opposed to make music :/ )
Old 02-15-2015, 09:06 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Cleaning up multiple tracks at the same time?
Originally Posted by JonesH View Post
Using AudioSuite you can select as many clips as you like and process them all at once. Seems like to me it would be better to listen to, analyze and process each track individually, but maybe in some cases you could use it on many at once.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 02-15-2015, 09:47 PM
Drew Mazurek's Avatar
I do a lot of live show mixing and whenever there's a bit of feedback, I wait until the mix is done and then RX the 2 track. Why make it harder than it needs to be?
www.drewmazurek.com
Old 02-16-2015, 12:27 AM
Thanks for your replies.
It is possible to use RX declicker, declipper et cetera as batch processing but in this case I need the spectral cleaning which I don't think is possible to use this way.
It might be better to do it on the mix but RX doesn't handle surround files so it will take some trickery. Also in the best of worlds I like to RX things and then let things like reverb smooth things out a bit.
Old 02-16-2015, 04:27 AM
Both very good reasons!! Good luck.
www.drewmazurek.com
How to stop multiple instrument tracks being triggered at the same time gutterfly macOS 1 12-07-2012 04:45 AM
Copying/Pasting Multiple Tracks at a Time KMAN385 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-30-2007 02:23 PM
time for a bath!! cleaning a procontrol? ChannelZero ProControl, Control|24, Command|8 1 01-22-2007 07:06 AM
time compression on multiple tracks KingTor Pro Tools TDM Systems (Mac) 13 04-04-2000 02:07 PM
Time comp/exp over multiple tracks-need help CCash Tips & Tricks 9 03-03-2000 03:33 AM
