Old 11-26-2003, 10:17 AM
Roy Howell Roy Howell is offline
Default Quick Reason question on pitch...
Bastiaan and I created a mandolin refill for Reason. I'm using it in the NNXT, and need to tweak the pitch a few cents sharper in places. Without recreating the whole Refill to be sharper, is there a place to adjust pitch in Reason, on an individual NNXT unit? The actual 'pitch' area inside the NNXT doesn't respond to the cursor.
thanks, Roy
rh music
Old 11-26-2003, 10:40 AM
pk_hat pk_hat is offline
Default Re: Quick Reason question on pitch...
Whether it's a loop or a multi-sample instrument (mandolin, in this case), make sure to select the zones on the left side of the 'unfolded' NN-XT before any of the synth parameters take effect. If there's more than one zone, click on one, then select all of them (apple+A, forgot the Win method), then all the parameters will light up, and the pitch knob should now respond accordingly. If only one zone is highlighted, parameters will affect only that zone, which is easily overlooked.
If you've already done all this, then I don't know.....??
www.myspace.com/krou
Old 11-26-2003, 10:45 AM
Thanks muchly, pk...I'll try it.
rh music
Quick Reason adapted question... danander11 Virtual Instruments 1 12-29-2008 04:57 PM
Serato - Pitch N Time (Quick Question) jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-19-2004 07:41 AM
Serato Pitch N Ttime (Quick Question) jordan23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-13-2004 09:00 AM
Quick 6.1/Reason question... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-05-2003 07:28 AM
* SPEED plugin - quick question on pitch control peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-30-2002 11:05 AM
