punch in track marks in real time?
I am recording dialogue and need to make track marks in real time while recording, and then use them to make a cd immediately after. Any help?
Re: punch in track marks in real time?
Select "auto name memory locations while playing" in prefs and you can hit "enter" when playing. Then, if your burning software supports it, you can tell it to use markers as tracks.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Make sure you use "enter" from the numeric keypad. The regular "enter" is RTZ.
Which burning software supports using markers as track markers?
Grant
PT9, Zed R16 & Macbook Pro i7 2.66Ghz |
Can you export files from the region bin and embed the markers? I dont think so. But you can "Export region definitions" to the audio file. That would enable you to use regions as track markers. Toast Titanium, at least, has this option. You’ll have to try it out. You could try this: (Make shure that all the audio is one continous file.) 1. Hit keypad enter to set markers. 2. Select marker 1 in the memory locations window and hit command-E to split the file. Select marker 2 and hit command-E, and so on, until you have a region for each CD track. 3. Select the whole-file and "Export region definitions" in the region bin. 4. Toast should now be able to ue the regions as track markers. Might just work.
I have a question about track ID makers for a live audio recording.
I want to put ID markers on a CD for the individual tracks and still maintain the continuity of the audience applauses. Can this be done with PTLE and Toast Titanium? Would you please explain how this is done or point me towards the info? Thanks in advance! [img]images/icons/smile.gif[/img] |
- Have the audio be one continous file in PT. Consolidate if it’s not. - Cut it up into regions. - Select the file (dual mono) in the region bin, and "Export region defifitions". - Drag the files (dual mono) to Toast and set it to use regions as tracks and set pauses to zero. (You should be able to preview it in Toast to see if it works.) I normally use Waveburner to do this.
Thanks Ben,
I plan to check it out this weekend. I'll post my results after I do. best regards! |
Continuously writing (or tapping) tempo track in real time | stevegalante | macOS | 3 | 04-22-2013 08:03 PM |
New Instrument Track has Real Time Properties enabled | Firechild | Pro Tools TDM Systems (Mac) | 0 | 08-18-2011 10:15 AM |
Audio stretch marks!! Pro Tools Time Stretching shootout | audiogeekzine | General Discussion | 6 | 01-09-2010 05:17 PM |
Can I set track marks with Pro Tools?? | philoton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-26-2006 09:40 AM |
Punching in Track Marks in real-time ?? | matthewhendrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-24-2003 09:24 AM |
