No TC plugs are being ported to aax. It was in an avid aax page somewhere. Shame as love my unwrap.
Who records with native? I record loads of commentary and some ADR .... Need to know that latency is low enough. Obviously won't be able to track with my plugs as it is not tdm or hdx, but can live without that as long as delay on punch in is acceptable.
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Re: Going HD Native for Post
I have been using PTs native with an RME QS-8 since protools 9 was released. I work with all reels in one session, including 2 prior of each reel, have all the tracks maxed out, record 16 5.1 or 5.0 stems to bring to the stage for temp dubs, and it has been flawless. We record ADR on a stage with an HD system so i cant answer that question sorry. The huge limitation of protools is still the track count. I have to have my BG's and Foley in separate sessions because of track count limitations, which appears will never be corrected in protools. 10,000 tracks would suite me just fine :)
Mike,
I record a lot of VO on just an Mbox. Latency is not an issue unless you overload your record track with plugins. Regards, Nick
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
Once you put the buffer to 32, there's no noticeable latency when recording. It all went swimmingly.
The Postman Post-Production Studio Moncton, New Brunswick, Canada IMDb (very partial) |
VO or ADR? VO is not sync so latency would be a non issue
#16
When we switched 8 of our smaller systems to HD Native from HD2, we had latency problems when doing ADR but later discovered we had the system set for at the maximum HW buffer size, dropping it down to a setting of 64 cured everything. Surprised how responsive it is even loaded with plugins and 40+ tracks. Only when you start piling on the memory hogs that you need to up HW Buffer for mixing.
6 months into it we really have no major problems, except we find PT9 no longer responds to Jam Sync when laying back to videos with spotty time code. But that is for another thread. Seriously thinking to upgrade all the rooms for PT10 even if the upgrade costs $1K per room. Native +PT10 seems sufficient so far for most our needs. I think we can stay this way till PT11 finally comes to town. |
#17
It's an issue if the talent's headphones are delayed.
#18
hitp: Are you monitoring through the protools mixer? (as most of us HD folks do)?
Not sure how many milliseconds it takes to start sounding weird, but it's not too many. Is HD-Native under or over that point? -jeremiah |
#19
If you guys love UnWrap, check out Waves UM226 plugin - I actually like it better!
#20
Thanks but no thanks. I dislike Waves for their business practices, even more now for their "sitting on the fence" with aax development. Rant over. Carry on.
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
Care to post your Native lowest latency at 32 buffers? | qbaser | Pro Tools HDX & HD Native Systems (Mac) | 22 | 05-08-2013 05:53 AM |
HDX Native cross grade for HD3 post - a roadtest | MIKEROPHONICS | Post - Surround - Video | 15 | 02-11-2012 07:34 AM |
SSL4000 native/ Renmaxx native/ DUY everpack native!!! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-22-2007 07:58 AM |
