Applying Instrument Tracks to Reg. Audio Tracks
Hi, this might be a weird question but, one of my plugins (Effectrix amoung others) can only be accessed when I'm on an instrument track yet, the plugin really isn't a virutal instrument, it's more like an effect that should be able to be applied to audio that I record.
Is there any way to re classify the plugin to show up under the inserts on an Audio track? Also, is there anyway to make it so that the effect only lasts for a certain amount of time before stopping (and maybe coming back in later)? Thanks! Here's some general info of what I'm using Pro Tools LE 8 Mac OSX 10.5 MBox Mini Thanks in advance. |
Re: Applying Instrument Tracks to Reg. Audio Tracks
Are you it's just not a stereo plugin, my Korg plugs are like this, no mono.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
What about instantiating it on an Auxiliary track? Then you could buss the audio track output and automate the plug-in bypass so that the effect is only applied where required.
http://www.myspace.com/philogg |
I'm pretty sure it works as a stereo insert only so make sure you're not trying to insert it on a Mono track. That would explain why it's not showing up in your list of plugs. |
Hmmm.... did you read my post above?
It DOES work on an audio track. It's NOT an instrument plugin. If it's not working, something is set wrong. Check the pic: http://img27.imageshack.us/img27/8362/effectrix.jpg |
No, I got it to work, just using Phil's technique. I'll go ahead and try it on a stereo track though just to make sure all is well.
EDIT: It works. thanks! |
Recording with instrument tracks and audio tracks | Shan B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2011 02:22 PM |
No audio on Instrument Tracks | DjTremor | Windows | 24 | 03-12-2011 05:16 PM |
Instrument or audio tracks | kasso | Tips & Tricks | 6 | 01-27-2010 04:58 PM |
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
Instrument tracks VS Aux tracks+MIDI tracks | mixaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-03-2006 04:08 PM |
