#51
Re: The Aux I/O device has disappeared from the system and will be disabled
#52
Only problem is once I saw the PT performance increase from running Native vs Rosetta, I don't want to go back (at least in my head); and on top of that source nexus (run as a plugin on a track) isn't available in Native, "forcing" me to use Aux I/O instead. I want to use it, because it's supposed to just work, and it might be perfect the way my system is configured, but I have to keep testing to try and make it crash to see if it's gonna be a problem for me and my workflow. Long story short, I WANT to use Native vs Rosetta. Just to give an example of the processing power of the M2 Pro in a real world scenario for me: Waves Clarity VX, using the 'Broad 1' algorithm: Windows 10 PC, I7 10th gen, PT 2021.12, Playback Buffer 1024 - about 3 or 4 instances Mac Mini Pro M2,Ventura 13.5, PT 2023.6 Rosetta, Playback Buffer 1024 - about 3 or 4 instances Mac Mini Pro M2,Ventura 13.5, PT 2023.6 NATIVE, Playback Buffer 128 - about 40 instances I was absolutely floored when I could do that many instances of Clarity. I've since moved on to Acon products, but still, it just shows you the power of PT running Native. It was a good objective test, at least for me. I also took a huge post session I did for a spot last year with tons of plugins and processing needed, and my PC rig was just about getting to the end of it's ability before I would be getting some 'running out of processing' errors at 1024 buffer. I loaded this session in PT2023.6 on the Mac in Native mode, duplicated the entire session's tracks 4 times, and it played back without problems at a 64 buffer. I loved that it has that much headroom. TBH I'm worried about a problem I haven't had yet (the error that it dropped on playback or record; not just my observation of it acting funny at first in the I/O), because I'm OCD with thorough testing and such; but yes, the I/O not sticking is a bug that I don't want to see, especially when the Aux I/O can apparently be dropped and removed DURING a session. Last edited by DJEJPRO; 08-07-2023 at 08:19 AM. |
#53
I totally see your point.
But now I’m curious, will the outputs be dropped if you launch PT in Rosetta mode? |
#54
Really baffling, but I import my I/O named "Native Audiobridge", and it's all back. Fortunately I'm not having to 'rebuild' anything, which is a term I've seen others use. I'm really not 'rebuilding' anything at all..I'm literally just loading my known good I/O and it's back instantly with no additional configuring needed. Easy workaround; annoying, but easy. |
#55
#56
Not sure what this might mean, since the virtual Aux I/O outputs (whether using the prebuilt file or a user modded one with custom devices) are still refusing to come up. Also, I tried again to import the 'Last Used.pio' file in the prefs folder and it's not where I left it. I really think there's something up with it saving this file correctly. It's the only chance Pro Tools has for the I/O to come back up with where it was, and it's just not saving it correctly. It IS saving something though, as the date/time modified always changes to exactly when I close PT, so it seems unlikely to be a permissions thing.. Last edited by DJEJPRO; 08-07-2023 at 03:33 PM. |
#57
Hiya folks! David here from the Community team! Has anyone created a case for this already? Please get in touch with me personally so I can have this looked at by the dev team. It seems that this has been going on for so long, correct?
Avid CoreAudio Device in System Preferences | Daryl Hughes | macOS | 4 | 01-01-2014 10:41 AM |
Mbox 3 not sticking as system output device | darwiniandude | macOS | 1 | 12-15-2010 01:27 PM |
I disabled Mbox in device manager - How do I enable again? | stev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-27-2008 02:32 PM |
master clock device for mix system? | digidesigner | Pro Tools TDM Systems (Mac) | 2 | 01-30-2008 01:53 AM |
Digi001 as preferential in\out multimedia system device? | salvo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-02-2000 01:40 AM |
