Old 08-26-2018, 12:06 PM
nesavant nesavant is offline
Default Can you turn off double click to rename region?
I'm cutting footsteps for a film and this is how I do it:
I have a long line of separated steps selected. My right click is rebound to be shift+left click, so I can sync the leftmost step, then double right click on the next step to deselect and reselect it, keeping the rest of the steps selected, and then I sync that step. So on and so forth.
On Mac, this worked just fine but I just switched to Windows and now I'm having trouble getting around the fact that if I double click (even shift+click) on a region too quickly, the renaming region dialogue opens.
Is there a way to disable that functionality or some other workaround?
Old 08-28-2018, 09:13 AM
Carl Kolchak Carl Kolchak is offline
Default Re: Can you turn off double click to rename region?
You can turn that feature off for MIDI clips (double click can, instead, open the MIDI editor), but I can't remember if that also disables it for Audio clips - probably not.
PT10.3.2 Can't Rename Region little78926 Windows 2 02-13-2013 01:37 PM
Disabling double-click to select region? PPM6 macOS 2 01-15-2013 03:10 AM
Disabling double-click select region? PPM6 macOS 1 07-29-2012 08:47 AM
Happened again - Double-click MIDI region CRASH (Reboot) GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 04-04-2009 01:10 PM
PT 5.1 Rename Region Bug? BackToMag Pro Tools TDM Systems (Mac) 6 06-04-2001 05:20 AM
