automation points
Hi.
Is there a way to change the automation point in to curves? The volume jumps to fast and it’s not ok. Is there a setting to make the change much smoother? Like letting ProTools knowing that I want a 5-7ms fade before acting? The “jump” is to fast and sometime it is too obvious.
Florin Milian OS X 10.9 / Mac Pro Early 2009 / 12GB Ram / Protools HD 11 with HD Omni/Native Core. PC Intel Quad Core / Protools LE 8.0.3 / Digi Rack 003+ / Win7-64 |
Re: automation points
I made a print screen to give details..
So, does Pro Tools have some volume curves, to replace points, for automation? It take to much time to write more points to make by myself that volume curve. volume automation.jpg
I don't know of a way to make PT automatically smooth out square/hard automation. You can make a selection (before to after the level jump), and hit the key X to create a linear ramp.
You could try "Glide to Current" in the automation section of the edit menu.
*this maybe HD only
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
Phantom Automation Points...arg! | kirkbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-25-2013 04:20 PM |
moving automation points | pinnacle | macOS | 3 | 08-05-2013 01:36 AM |
PT 10.3.4 is creating automation points. | Rickaudio | macOS | 7 | 04-03-2013 01:31 PM |
PT 8 Automation Break Points | myke2242 | Post - Surround - Video | 7 | 04-20-2009 10:17 PM |
Keep losing automation points | DEXTERITY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-18-2005 05:05 PM |
