Old 06-09-2014, 01:56 PM
hbadger30 hbadger30 is offline
Default PT 11 HDX Sidechain delays
Hi all,
I've read the manual on this a lot but I have to admit I'm having trouble getting PT 11 to do what I think it should be doing with regards delay compensation and sidechains.
I've set up a simple 3 track session with a sidechain (very short bursts of white noise on each beat of the bar), a sine wave that lasts a whole bar and a record track. I'm routing the sidechain to the sidechain input on a Waves H-Comp which is across the sine wave track. The output of the sine wave track is then routed to the record track. All I want is for my recorded sine wave to show the compressor being triggered on each beat of the bar (as per my sidechain track) but there appears to be a delay.
I've tried toggling the 'compensate sidechains' checkbox under the operations tab, I've tried routing the sidechain source track to an aux first and then to the H-Comp, and I've tried with delay compensation on and off but I can't get the compressor to trigger exactly on each beat of the bar.
Is this a known bug? Or am I doing something wrong? Or is there a better way to set this up? Or are you guys manually adjusting the side chain source?
System spec is:
PT11.1.3, HD Omni, MBP, Magma 3T Chassis, HDX, OSX 10.8.5.
Thanks in advance.
Old 06-09-2014, 08:47 PM
drewbixmusic drewbixmusic is offline
Default Re: PT 11 HDX Sidechain delays
I think this is a bug related to the other delay compensation anomalies people have been experiencing with PT 11.
I recently spent half a day setting up and tinkering with an elaborate side chain signal path to trigger my mix busses so I could bounce stems and still achieve the same dynamics as if the entire arrangement were there...and that faulty delay compensation spoiled my efforts hard.
Here's to hoping for 11.2!
Old 06-10-2014, 09:26 AM
Many thanks for the reply drewbixmusic. Can anyone from Avid confirm this is the case please? And if so, is there any timeline for fixing this in a CS update?
What are people doing as a work around? Using PT10HD?
Thanks in advance!
Old 06-10-2014, 02:26 PM
C C is offline
Could you try it with a AAX DSP plugin instead of the Waves H?
As Waves is native only and you are on HDX it's not the greatest test (not that it shouldn't work but reduction of variables is important)
You may not like the sound but the Avid Dyn3 I believe is AAX DSP capable, has side chains etc
Let us know
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 06-12-2014, 11:00 AM
Hi C,
Thanks for the reply - I've done a little more testing and indeed there seems to be differences between Native and AAX DSP instances of the same plugin (see attached session pic. It appears that there is a latency with the Native Plugins (which is a shame because I quite like the Waves H Comp). Also the amount of delay in the Native plugins seems to be plugin dependant - the H Comp being the worst offender in this case.
Looks like using an AAX DSP comp for sidechaining is the way to go at the moment but I'd like know (and will do some more tests) the implications for using a Native plugin either before or after your AAX DSP comp - will this mean that the side chaining then becomes delayed?
Any one from Avid want to comment on this? It would be great to get some definitive answers.
Many thanks!
Sidechain set up? bzb888 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-12-2005 10:34 AM
Sidechain dfusion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-12-2004 05:08 PM
BUS, SIDECHAIN, AUX...ETC JAEPILLA Tips & Tricks 3 06-03-2004 05:42 AM
Sidechain, how??? rose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-06-2002 08:25 AM
sidechain ballerina Pro Tools TDM Systems (Win) 0 07-26-2000 04:07 PM
