Compatibility Alert: Mac OS X 10.6.8 with HD Native
Avid is tracking reports of kernel panics on HD Native systems after updating to Mac OS X 10.6.8.
At this time, we have not officially qualified Mac OS X 10.6.8 and we specifically recommend that HD Native customers do not update to 10.6.8. |
Re: Compatibility Alert: Mac OS X 10.6.8 with HD Native
This issue has been identified and resolved. See the following:
Mac OS X 10.6.8 Officially Qualified
Administrator Avid Pro Audio Community |
Just updated to 10.6.8 (downloaded 9.0.4 but haven't installed yet) and my mac won't boot up unless in safe mode...
Ran any kind of fix out there (disk utility from install disk, techtool pro, applejack) and nothing. Unless in safe mode, it won't boot. I tried starting in safe mode, then run the PT updater, but it fails every time. Help?
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Avid's instructions specifically say to update to 9.04 BEFORE updating to 10.6.8. Otherwise... what is happening to you will happen.
I would take the HD card out, and I bet it will boot. Then update to 9.04 before re-installing the card. Also, just double check Avid's instructions, because they're pretty thorough and you missed step 1 completely. Hope this helps. Rob Burrell aka mixboy
http://www.robburrell.com PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA |
Thanks Rob, I guess I did... :/
Restored back from TimeMachine and will attempt again after my session tonight...
Sounds like the best plan
Good Luck!! Rob Burrell aka mixboy
The Native card firmware will only update under 10.0.7. Once that's done, 10.6.8 w/9.0.4 works fine.
Ron Stephens [email protected] Latest Pro Tools Studio, macOS 14beta, Mac Studio M1. |
So to beat a dead horse a bit more:
With me being at 10.6.8 (not 10.6.8v1.1) and getting the "unable to find interface" error, I need to downgrade to OS 10.6.7, then run the PT9.0.4 updater, then update my OS to 10.6.8v1.1? Do I need to run any other PT updates or drivers at that point? Ot should it be smooth sails? Thanks for your patience, it's just a bit of work and I want to make sure I'm not doing it in vain. Jahhn |
Or even...should PT9.0.3 "just work" when I down grade to OS10.6.7? Maybe the lesser of two evils for me at this point...
Thanks again, Jahhn |
I didn't need to re-install interface drivers. |
Mac OS X Lion Compatibility Alert | Avid | Technical Alerts | 0 | 07-20-2011 11:20 AM |
Compatibility Alert: Pro Tools HD Native with 2011 MacBook Pro 17" | Avid | Pro Tools HDX & HD Native Systems (Mac) | 1 | 06-27-2011 09:31 AM |
Compatibility Alert: Mac OS X 10.6.8 with HD Native | AvidCS | macOS | 0 | 06-27-2011 08:17 AM |
HD Native with MacBook Pro 2011 17" Compatibility Alert | Avid | Technical Alerts | 0 | 04-08-2011 11:11 AM |
Mac OS X 10.4.9 Compatibility Alert | Avid | Technical Alerts | 0 | 03-14-2007 06:34 PM |
