Old 01-06-2022, 08:42 PM
its2loud its2loud is offline
Default Re: Looping PT+Atmos Suite into consumer Home Theater
Originally Posted by djh108 View Post
Oh and to answer your other question, yes I’m using powered speakers. That’s what led me to the pre pro option in the first place. The main point of confusion for me was understanding what kind of signal I’d be able to send from the computer, and what sort of connection would be able to support it.
And secondarily, if pro tools was gonna react weird to anything, specifically what sort of playback engine I’d end up needing to use. But using audio bridge has assuaged some of those concerns.
But in terms of hdmi, are you sure your info is up to date?
https://www.audioholics.com/audio-video-cables/hdmi-2.1“Thanks to the vastly increased bandwidth of HDMI 2.1, eARC can handle 32 channels of uncompressed audio…”
The device is earc capable…
eARC. or Extended Audio Return Channel is for getting sound from your TV, Apple TV 4k, or other streaming device into you AV processor. Which then processes the signal to send out to your speakers.
There are no Macs that I know of that support eArc with individually assignable channels.
I suppose you could try hooking up the PreAmp to your computer via HDMI and go into the Audio Midi Setup to see how many channels it will provide but you'd also have to see if that could be used as viable output for Dolby Renderer.
I you're trying to stick to using HDMI as your input source, I suspect you're going to need some type of audio embedder to convert the Dante to HDMI. But don't know of any such device that will handle multichannel audio.
Old 01-06-2022, 08:50 PM
djh108 djh108 is offline
Cool. Don’t really care how I send the signal. Just hoping to be able to figure out a way to do it. Im going to go ahead and get DAPS and do some experiments and also see if I can get some more clarity about the usb input. Thanks again.
Old 01-06-2022, 11:10 PM
The USB port is most likely for connecting a media loaded hard drive for playback by the AV unit. Not to be used as interface connectivity for multichannel pass through
Old 01-07-2022, 06:49 AM
Yeah that does seem to be the way those ports work on many units.
Though the port is labeled “USB (For PC)”. The only thing the manual said was “For Playing PC Audio” which may just be unclear translation.
Old 01-07-2022, 11:33 AM
Actually, looking closer, there is a separate usb connection on the front that I learned from a user review is what is used for playing media from a disk…which gives me a little hope for the other “pc audio” connection on the back. I’ve reached out to the distributor and the reviewer to try and get some clarity.
  #16
Old 01-07-2022, 11:36 AM
I'm willing to take a guess that it's for any firmware updates to the device.
  #17
Old 01-07-2022, 11:54 AM
epm epm is offline
I'd be willing to bet that even if it's a class compliant USB audio device that it's stereo only.
-Evan
  #18
Old 01-08-2022, 01:15 AM
Maybe. But like I mentioned above, the (only thing) the manual says about the port is it’s “for playing pc audio”. Though I concede stereo is likely. It’s crazy to me that someone hasn’t just made a solution for this use case. Every single dot is sitting right there, you’d think someone would just go ahead and connect them.
  #19
Old 01-08-2022, 01:16 AM
Agreed likely.
  #20
Old 01-10-2022, 09:05 AM
resonantRhythm resonantRhythm is offline
Hey...
As has been said before...you're making this WAY too complicated.
The ONLY REASON you involve a receiver is to DECODE a [Dolby] Atmos signal.
When you're mixing...there is NEVER an [Dolby] ENCODED signal. Period.
The ONLY times you're going to encounter an ENCODED signal is:
1. Playing an MP4 export from DAPS
2. Playing STREAMED Atmos content through a service [Netflix/AppleTV]
2a. Current an Apple TV device is the 'easiest' to stream an Atmos signal into your receiver.
These are 2 separate flows....if you have an audio interface with enough inputs and a receiver that outputs line-level audio you could feed your audio interface with the output of the receiver allowing you to monitor a consumer decode of content (whether that's Netflix or your own mp4).
HTML code is On
minimum room size for Dolby Atmos Home mixing suite Mishabou Post - Surround - Video 4 10-10-2021 02:28 PM
Is there a way to use a 7.2.4 Dolby Atmos home theater as a Pro Tools Dolby Atmos mix Focuret Pro Tools HDX & HD Native Systems (Mac) 19 09-14-2021 08:52 AM
AppleTV/Blu-Ray - Consumer Atmos/DD51/DTS integration in mixing environment leopod Post - Surround - Video 3 02-08-2020 08:16 PM
The Dub Stage Installs Dolby Atmos Home Theater dr sound Post - Surround - Video 1 08-24-2019 09:52 AM
OT: Question on my Dolby Atmos experience in a theater nst7 Post - Surround - Video 1 08-11-2014 02:18 PM
