chaning buffers between recording/mixing
I am a musician doing home recording, mostly 2-3 channels at a time. I have been using the 003 and when I started I learned to set the buffer low when recording and high when mixing. This is pretty easy to do in Pro Tools with the 003 and I go back and forth a lot, as within the same song I'll do some mixing, decide to add instruments or back up vocals, more mixing, re-do tracks I don't like, etc. I know this is not the workflow of a standard studio where generally you would record everything, edit, then mix and master once everything is done, but it is just not the way I work and hasn't gotten in my way with the 003.
I tried out a TC Impact Twin a few weeks ago and I loved the sound quality compared to the 003, but h/w buffer had to be changed in the control panel, not in Pro Tools. It gave me a lot of issues when I tried to go back and forth, re-starts, crashes, etc. The guy at the store says he never heard that you need to change buffers, that once you get a setting you stick with it whether you're recording or mixing. Is this true, even if you are using heavy-duty plugins? I am using Windows 7 64 bit with 8 GB ram, Intel I5, Pro Tools 10. So I have ordered a Fast Track C600 (still waiting for it) hoping it will be at least close in quality to the TC Impact Twin and not have this issue (I also like some of its other features better), but reading the manual it says that in Windows you can't change the buffer either without re-starting Pro Tools. Is this a trend now that Pro Tools is working with all hardware, that there is no direct control from within Pro Tools? Is changning buffer sizes a lot something people generally do these days or is it a thing of the past? Any insight would help! |
Re: chaning buffers between recording/mixing
Many of us still do it. Not everyone. A few lucky people can get away with keeping low buffer sizes all the time. But many. Maybe most. I generally print heavy tracks like those with VIs or guitar amp sims once I'm sure I've got the sound I want. That way I can keep the buffer size lower longer. If I need to track a rhythm-sensitive part in a really huge mix, I'll even print a stereo mix of the whole shebang, disable everything but that stereo track and the new track, set the buffer to 64, get it recorded, then raise the buffer back up and re-enable everything. You do what you have to. Whatever it takes to get the job done is the right way.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
To the OP, your computer seems pretty powerful, I wouldn't increase the buffer unless you are getting errors when you start to add lots of plugs. Don't just increase it because of the rule "record low, mix high". Try keeping it at 128 for both recording and mixing. You will not hear any noticeable delay while tracking until you hit 256 and up!
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Re: changing buffers between recording/mixing
Thanks to you both for responding, this helps a lot. I am still concerned that I will be faced with the same problem with the fast track C600 as with the Impact Twin, a problem I don't currently have with the 003. I guess I'll have to wait and see and try to return it if I have the issue. Maybe I can get away with a buffer of 128 for recording and mixing most of the time and this will become a non-issue!
128 is a bit long for me. 64 is just on the edge of comfortable. I wish to goodness I could get mine down to 32, but that's a Mac-only thing at this time.
The problem with the Fast Track is that it's USB. Firewire interfaces will always get you lower tracking latency than USB ones. Stay away from the USB variety if you're interested in keeping low buffer sizes/reasonable latency.
Anyone using UAD cards and pugs in PT is jumping up to 1024 to mix.
So, does anyone know any interface that can be considered an upgrade to the 003 in terms of pres and converters, minimum of two preamp channels and one high-z instrument channel, that works as well as the 003 with pro tools under windows in terms of changing buffer size without a restart?
Really? You can hear the delay at 128?
yeah, I hear their mod is great, it's a bandmate's 003 (I suppose I could buy it off him he bought it and has no idea how to use it), my main worry is the 003 will no longer be supported by Avid to my knowledge so I hesitate to invest money into it.
I've been doing more research and it seems RME Babyface is rock solid with Windows and Pro Tools and can change buffer size seamlessly without a re-start. Still trying to figure out if I can use two sets of monitors plus two headphones with the things. Unclear to me how mbox 3 will behave. Difficult to get good info on this. |
The newest of the Mbox Pros is supposed to fit that bill. Can't vouch for it myself, but a number of people I trust have.
Succesful realtime recording of VIs at low (32, 64) sample buffers in PT11 native? | yeloop | Pro Tools 11 | 11 | 01-03-2014 04:17 PM |
Daisy Chaning Multiple 002's ? | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-10-2007 10:02 PM |
Serious recording/mixing | puckot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-04-2004 10:16 AM |
Recording in PT- Mixing in SSL | Aardvark | Tips & Tricks | 3 | 03-11-2003 05:18 AM |
Recording in PT-Mixing in SSL | Aardvark | Pro Tools TDM Systems (Mac) | 2 | 11-10-2001 12:41 AM |
