2021.3 new error "playback could not be started because of an engine reset"
I have a new error that keeps popping up about every 5 mins...
"playback could not be started because of an engine reset" Anyone else having this new issue, know any fixes? Last edited by bassmagnetic; 04-29-2021 at 04:45 AM. |
Re: 2021.3 new error "playback could not be started because of an engine reset"
It happened to me a couple times on an iMac I'm working on today. I don't have any other info on it though.
Tough to offer help with zero details on the setup Shooting from the hip, is it a Windows setup and you didn't disable Power Management on all USB ports?
happening like once every 5 mins... its annoying...
thanks albee1952... I hadn't done that, but I now have but it didn't make any difference... Windows 10 PC ASUS Prime X299-Deluxe i9-7980XE 18 Core RME 802 |
This happens to me, too.
Sometimes I don't get the error message, only the rotating mac-ball, and after 5-10 secs I can work again. Still quite frustrating. I'm on a 2015 Retina 5K 27" iMac, Quad-Core i7 4.0 GHz. Pro Tools 2021.3.1 I followed the optimization guide and trashed the preferences. No difference. |
I unchecked "Optimize Performance at Low Buffer Sizes" in the Playback Engine window. It seems the error message doesn't pop up as frequently now, but I'm still checking.
(Buffer size is set to 1024.)
PT Ultimate 2022.10, MTRX Studio, MacPro 3,2 GHz 16-core (2019), Eucon 2022.9, macOS Monterey, Avid S1, Avid Dock, Dolby Atmos Home |
I've seen it a number of times, but it's not chronic. For me, any playback stoppage like this generally happens either when I've first loaded a large session, or when I'm doing rapid-fire editing. And mostly—if not exclusively—when there's video involved.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
I'm starting experiencing this, it's annoying. It's happen randomly. Any kind of session size (small or big)--but it's always with picture. I have try moving the session to directly attached SSD, but still happening.
It started to happen after I upgrade the OSX (Supplemental update) and the ProTools (2021.7). Any solutions? Thanks.
Satrio Budiono FourMix JFS Mac Studio Max M2 (2023), 32GB RAM, Ventura 13.6.4, PT Ultimate 2023.12.1, Sonnet TB2 III-D, Avid HDX 2, Sync X, MTRX Studio, Trinnov D-Mon, JBL 708P, 705P & JBL 3635 (Atmos HE 7.1.4) |
I'm also seeing that error on a newly set up rig. It's a Mac Pro (Late 2013), with an HD Native card in a Thunderbolt expansion chassis. Any ideas?
I am experiencing the same thing with a 2018 mac mini (64Gb i7) and an HD native card in a Sonnet Echo III thunderbolt expansion chassis. Did you solve the problem?
"The current playback engine does not support a sample rate of 0kHz" | Kahlil_J | Pro Tools 12 | 1 | 01-27-2016 10:04 PM |
"The current playback engine does not support a sample rate of 48 KHz" error when tr | eyeshow | Pro Tools M-Powered (Win) | 19 | 09-09-2015 10:10 AM |
"Current playback engine does not support a sample rate of 48 khz" | pribb1 | Third Party Interfaces | 28 | 07-01-2015 08:47 AM |
"current playback engine doesn't support sample rate" | terracestudio | Windows | 2 | 04-17-2015 02:37 PM |
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 | beasleymusic | Pro Tools M-Powered (Win) | 1 | 04-02-2011 03:17 PM |
