Poly pressure message on PT 8
Hi and thanks for reading;
I'm using PT 8 on windows and I'm sequencing a Virus C. I've been recording automation with both controle change and Sysex but cannot find the option for polypressure. I've been using the Virus for some time now so I'm pretty sure the config on that end is correct. The reason why I want to record polypressure is that the parameters that are not Control change are either Poly or Sysex but the Sysex is a nightmare for me to edit and the Poly should show up the same way as CC. Is there an option I missed in PT ? Much obliged thanks |
Re: Poly pressure message on PT 8
For some reason, the aftertouch is often checked in the "record everything but" section... Take a look
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Indeed it was. I didn't know that the aftertouch is the pressure ( or is it ?). I checked the manual and no you can't see poly touch as you would CC ( lines and stuffs ) but you can in the midi event .I guess I'm gona have to get my head round it. Still easier than Sysex though . Thanks for your help cheers
poly wav files and PT 9 | allegrarc | macOS | 0 | 09-05-2013 06:31 AM |
Imac 10.4.7 & pro tools 7.3.1 ???????grace under pressure | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-03-2008 04:41 AM |
Exporting poly wav in 44k fails | demodigi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-17-2007 05:00 AM |
Xpand Poly/Mono | yamlan | Virtual Instruments | 5 | 05-03-2007 02:00 AM |
New Poly 800 Pluggo | The Lone Roger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2004 08:02 AM |
