  #31
Old 08-23-2023, 02:17 PM
andymixer andymixer is offline
Default Re: Very slow to activate/deactivate DSP
I installed some updated Plugin Alliance stuff recently and at least the SSL channel strips I use seem to have improved. Ironically I updated my McDSP CS 6050 for $29 buck and now clicking on the plugin even in Native mode hangs for about 5 seconds.
  #32
Old 08-25-2023, 08:01 AM
digiot digiot is offline
Finally had time to get my PA plugins updated. So they seem to work as before.
Meaning that when I pulled up a tracking template filled with PA Plugins and turned on DSP mode, it took about 20 min to switch from Native to DSP
  #33
Old 08-26-2023, 09:13 AM
My experience constantly although I can never nail the exact plugins or combinations down. Obviously this is untenable work flow. This entire element of the product seems to be unusable in its current form. 😠
  #34
Old 08-27-2023, 07:03 AM
Did a little more testing and came to the conclusion that some plug-ins (mostly PA in my case) will start the slow switching behavior when going over about 5 instances. So I either don't use any of the PA Plug-ins or I keep it down to no more then 5 while in tracking/punching mode. Since I had to stop using them about 8 months ago when I switched to an M1 computer with Protools 2022.12, I had gotten used to using only Avid,McDSP and EmpiricalLabs plug-ins.
I mentioned before in this tread that it is a specific Carbon Hybrid engine issue and obviously some developers have had no issues with it. EmpiricalLabs for instance, was able to fix it within days of me and several others reporting it to them. They contacted Avid and worked it out with them and had a fix in less then a week. Sonnox acknowledged the bug but didn't bother to fix it saying it was an Avid problem. Their loss.
  #35
Old 08-27-2023, 07:13 AM
yep, 5 is the magic number, I agree.
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
  #36
Old 09-20-2023, 01:23 PM
I just heard back from PA after filing a ticket and they seem to have no clue on to what's happening. So please anyone with PA Plug-ins and Avid Carbon's file a ticket with PA! And make sure you mention you are on an Avid Carbon since that's the main differentiator as supposed to an HDX system in Hybrid mode.
Sonnox replied a while back saying they were able to reproduce it with their Plug-ins but don't seem interested in fixing it. Saying it was Avid's problem to fix.
  #37
Old 09-21-2023, 01:26 PM
So I just loaded up 2023.9. And damn does that make a difference.
Loading up 12 channels with PA Channel Strips and switching to DSP now takes about 2 min! That took 15 min before!! Even better the Plug-ins that worked better before now even switch faster lol. ArouserLT on 12 tracks now takes about 3 sec to switch. Avid ChannelStrip takes less then a second!
  #38
Old 09-22-2023, 01:15 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Thanks for letting us know it's improved!
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
"Lock To Application" activate/deactivate anason-records Avid S1, S3, Dock and Control App 2 10-02-2021 07:59 PM
Can't deactivate PT First Dale-c Pro Tools | Intro Discussion 0 05-23-2020 10:43 AM
The De-activate/re-activate plugins routine nightmare superbask Pro Tools 9 0 03-21-2011 11:51 AM
4-band EQ sound change on activate/ deactivate maedde Pro Tools TDM Systems (Mac) 0 05-26-2009 09:22 AM
Deactivate all plugins? Beauchampy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-22-2006 11:19 AM
