Old 03-22-2013, 09:34 PM
bashville bashville is offline
Default Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also?
I'm looking at a used MacPro. Checking the qualifying Macs list, and it says "Westmere", but not "Bloomfield" or "Gulftown", even though they're from the same generation. Does the "Westmere" qualification apply to all three of those?
thanks
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 03-22-2013, 10:34 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also?
Hang on for one of these avid employees floating around and u should
Get an answer
Maybe Saturday maybe Monday -
Daniel
Old 03-22-2013, 11:14 PM
panamajack's Avatar
panamajack panamajack is offline
From Tom's Hardware: Intel makes those. Westmere and Bloomfield are die/architecture revisions.
As far as the differences goes, Westmere is on 32nm where as Bloomfield/Nehalem is on 45nm. They are both on the same architecture. Only the manufacturing process differs. Generally, the 32nm CPUs should run cooler.
From Wikipedia: The architecture of the Nehalem was the basis of the i7, which was revised in 2011 as sandy bridge. The Westmere is a more recent CPU. Westmere-EP is the first six-core dual-socket processor from Intel, following the quad-core Bloomfield and Gainestown (a.k.a. Nehalem-EP) processors using the same LGA 1366 package, while the earlier Dunnington six-core processor is a Socket 604 based multi-socket processor. The CPUID extended model number is 44 (2Ch) and two product codes are used, 80613 for the UP desktop/server models and 80614 for the Xeon 5600-series DP server models. In some models, only four of the six cores are enabled.
If you were building your own Hackintosh, die revisions might have more significance. However, if you are shopping for an Apple Mac Pro, check out
www.everymac.com
You will find a comprehensive list of most of the retail products, including the incarnations of the Mac Pro. The speed of the processor is an easier way to figure what kind of performance you can expect.
The Hackintosh, user-built servers, or Frankenmacs, open up the possibility of overclocking, which is where you would want the coolest running CPU you could find.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 03-23-2013, 08:32 AM
I've also been referencing the "Mactracker" app
http://mactracker.ca/
and it seems to go into more detail than other sources, naming these other chip designations "Bloomfield" and "Gulftown" for the MacPro5,1. I'm wondering if those are all covered by the "Westmere" umbrella.
The other issue is that Mactracker doesn't mention "Nehalem" for the 5,1, whereas EveryMac does. The machine I'm looking at is a Quad-Core 3.2, which EveryMac says is a Nehalem.
Old 03-23-2013, 08:47 AM
panamajack's Avatar
My Nehalem Mac Pro is early 2009, and is designated 4,1.
Everymac does show which Mac Pros had the 45nm vs 32 nm.
ProTools with Mountain Lion is supported back to the early 2009 Nehalems.
The issue is that not all the software out there can truly take advantage of a dozen cores. The other issue is the expense of a dual six-core vs a single quad core. Initially, some users were reporting better results with a faster quad core vs a slower octo core.
Old 03-23-2013, 03:04 PM
OK I think I'm starting to get it. Thanks PJ
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... tohmit macOS 5 03-23-2011 12:13 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
