Transfuser: Recording in the Drum Pattern Editor
Transfuser Question:
I'm trying to record in the Drum Pattern Editor using my MIDI controller to control the 12 pads instead of drawing in the hits manually. Is this possible? I tried using the record button while the pattern is playing but nothing gets recorded. I can hear the sounds from each pad as I press them but the Drum Pattern Editor doesn't record what I play. EDIT: Problem solved: I had Transfuser set to Transfuser Synth instead of Transfuser in the Mix window :)
(PT12.4- Win7Pro - mboxpro3 -Axiom25- Maschine) |
Drum Pattern Sequencer | AdamPT8 | MIDI | 21 | 03-13-2010 02:09 AM |
drum pattern to pt instead of just midi notes??? | jolita | Pro Tools M-Powered (Mac) | 3 | 01-04-2010 11:41 AM |
Transfuser: Recording a drum pattern | Robin Henkel | Virtual Instruments | 0 | 11-15-2008 10:43 PM |
Pattern/Sequence editor for EZDrummer? | Bill0287 | Virtual Instruments | 4 | 10-03-2008 07:40 AM |
Drum Pattern Editor | anthonymunoz | Virtual Instruments | 3 | 05-29-2007 08:11 PM |
