external drive power eating!
Hiya,
ok, so I managed to scrape together enough cash to buy an external HD for my setup: Digi 002Rack, Titanium Powerbook 1GHz, 1G RAM. Maxtor One-Touch 250G External Firewire Drive. I've noticed that when the external is my target drive for the audio (as recommended), it seems a lot tougher on the processer regaurdless of the CPU level etc. Basically, I can't run as many plug-ins while using the external drive as I can when using the internal laptop drive. IS THERE ANY WAY AROUND THIS????? thanks!
Prism Orpheus, PT 11, Mac 2x2.26GHz QuadCore Intel Xeon, 16g ram Outboard - ADesign, Chandler, RetroDesign, Roland. |
Re: external drive power eating!
Come on! There must be someone out there with a suggestion?
thanks, steve
FireWire requires CPU cycles to manage the buss. The more devices on the FW bus the larger hit to performance. The biggets performace hits will come when the most amaount of bus management is requires (during extended or heavy read/writes).
Use a FW800 drive on the FW800 bus or get a FW CardBus adapter to offset the load. These is the only option at the present time. Also, be sure you are using an Oxford 911 or 922 interface bridge on the drive to insure the least load on the bus, and format the drive using OSX before usig it (performance always seesm better after a reformat from the OSX Disk Utility). FW will mature and things will get better.
Steve Always err on the side of perfection. |
Why does Avid recommend external USB over external Firewire for audio drive? | DJ Hellfire | Pro Tools 10 | 10 | 03-29-2012 09:39 PM |
control surface eating up CPU power? | GothicV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-22-2005 07:50 PM |
External audio drive, leave power on or off? | jwd65 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2004 12:40 PM |
External Hard drive is hogging my processing power | dj_fred_d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 09-02-2004 10:43 PM |
Stereo Mixer eating all my DSP power. | julianmm | Pro Tools TDM Systems (Mac) | 4 | 05-23-2002 12:32 AM |
