Old 08-05-2014, 11:45 AM
J.D. Andrew J.D. Andrew is offline
Default Plugs that were formerly HW inserts don't save new plugins?
I'm having a problem where I have a session. I import session data. Some tracks used to have hardware inserts, but I'm importing new plugs in their place. I work on the session and then save and close. When I open the session again, the hardware insert (greyed out because it no longer exists) is in the place of the plug in that was imported.
I'm on 10.3.9 on mac os 10.8.5. I have trashed all prefs/setups etc.
Anyone else have this experience?
Old 08-06-2014, 12:17 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Plugs that were formerly HW inserts don't save new plugins?
Try completely removing the hardware insert first, then insert your replacement plugin, or after you've removed the hardware insert, use a new slot to insert the plugin.
I have seen some strange things with hardware inserts when re opening sessions, especially on disabled track.
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-06-2014, 04:13 PM
Hi Chris.
Yes, that seems to work. I removed all of the hardware inserted (deactivated) plugins before importing, and haven't had the problem so far today.
I do much prefer being lazy and not having to remove before importing, but will do so to save piece of mind.
thanks
jd
Profile wont save inserts correctly JohnEvans VENUE Live Sound Systems 14 02-26-2015 04:06 PM
Inserts not displaying any plugins fullscale macOS 1 08-28-2012 01:51 PM
Don't see my plugins in inserts sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-21-2007 08:58 AM
Inserts/Plugins won't work... bussboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 01-06-2006 09:47 AM
Rev Plugs as Inserts or Returns ... ??? Don Geppert Pro Tools TDM Systems (Mac) 2 11-08-2004 08:29 AM
