control surface eating up CPU power?
Hello! I recently got a control surface, and plugged in USB or midi, it still seems to stop me from doing anything [lots of increase hardware buffer size errors]. I have used it a bit for mixing, however for tracking I have to disable it due to the need for low buffer settings.
I think there's a sync problem, I had this same thing going on with my motu MTPAV when I didn't have it set up correctly. Though the motu was wiggin out with a 1 midi file session with the buffer set to max. anyone have an answer? I hear it works better running through a midi port instead of usb [yes it is the behringer one] I have a session coming up on Saturday that I would like to have it up and running by then. This thing is great when I have it on high buffer settings, but right now I have 12 tracks running with no effects and I can't even go at 256! 512 will run for 2 minutes and then 1024 will run until I tell it to stop. Without the controller on I can run the session just fine. |
Re: control surface eating up CPU power?
My Cm Labs MotorMix (midi) works great tracking at 64 and mixing at whatever I set it to (64 to 512)
Hmmm.
5198 Studios |
What DIGI interface are you running? If its Mbox, the problem may be that the Mbox isn't sharing the USB nicely. Maybe you could run one of the devices on a powered hub?
What kind of controler do you have?
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
like I said, I have the behringer fader controller. I am running a 001 setup, with a motu MTPAV for extended midi. I seem to have it setup all nicely now, I just hope it lasts.
It's hooked up straight into the 001's midi now and I turned the midi mode to s-3 and that seems to have done it, though the manual says s-4. Stupid behringer and their crap manuals. I don't like using the USB mode, it makes you have to think of the order when you fire up PT |
5198 Studios |
5198 Studios |
yeah man!
I had same problem after some weeks with my BCF2000 and someone in DUC said change to control device via midi port (not usb) and works fine but i´m frustrate. I would like to conect via USB! I´m waiting the solution on the DUC as always!! |
When you say:
"It's hooked up straight into the 001's midi now and I turned the midi mode to s-3 and that seems to have done it, though the manual says s-4." Does that fix your problem, or is that how you have it hooked up when you have a problem? I am having a similar issue, although my B-Controller is set to s-1, so if what you did fixed it, than I will have to try that. |
When I say I have it hooked up to my 001's midi inputs, I just thought to clarify because sometimes the motu needs to be restarted if I don't open things in the proper order. I believe switching to S-3 did the trick however.
anyone get this thing controlling plugins? |
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Mackie Control Universal or Tascam 1082 for control surface? | anders | Pro Tools TDM Systems (Mac) | 5 | 05-28-2007 06:12 AM |
external drive power eating! | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-22-2004 01:47 PM |
Stereo Mixer eating all my DSP power. | julianmm | Pro Tools TDM Systems (Mac) | 4 | 05-23-2002 12:32 AM |
