Pencil Tool Problem
I've been using HD 5.33 and the pencil tool doen't alow me to edit audio.I'm zoomed in all the audio files are unlocked.Digi tech support doen't hav a clue to this one!
P4 2.5 all Intel mobo 850mvr Xp pro 1gig ram bus system runs protools that's it! Any Clues!!!!!! Phil Plaskon [img]images/icons/grin.gif[/img] www.tenkproductions.com |
Re: Pencil Tool Problem
I had the same problem. Digi says it (maybe) happens if you have 1GB or more ram.
Try setting the Paging File Initial Size to 1065 or lower in Virtual Memory. 1024 is the recommended value. To set this, go to: SystemProperties>Advanced>Performance>Settings>Adv anced>Virtual Memory>Change I put 1024 in init. and max. - and it works fine here |
If you select around the area and consolidate it before using the pencil.. does that work? There was a similar thread recently on the Mac side where this can happen when you have imported (via OMF) files.
Rail
Thanks Guy's
I found that post in the answer base about the 1 gig of ram.I removed 512 so I have 512 in the system and restarted launched protools opened a session and used the pencil tool.It works fine now Who Knew! [img]images/icons/grin.gif[/img] Phil Plaskon www.tenkproductions.com |
Free Hand Pencil Tool Becomes Line Pencil Tool | Vogger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-27-2009 10:23 PM |
problem with pencil tool while trying to fix a wav | rastayan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2003 01:55 AM |
problem with pencil tool | DrakeGiles | Pro Tools TDM Systems (Mac) | 7 | 09-18-2002 09:17 PM |
problem with pencil tool | DrakeGiles | Pro Tools TDM Systems (Mac) | 2 | 09-17-2002 09:18 AM |
Pencil tool for digital pop problem | dkrausz | General Discussion | 8 | 04-15-2002 11:08 AM |
