Old 01-28-2003, 04:23 PM
tenkproductions tenkproductions is offline
Default Pencil Tool Problem
I've been using HD 5.33 and the pencil tool doen't alow me to edit audio.I'm zoomed in all the audio files are unlocked.Digi tech support doen't hav a clue to this one!
P4 2.5 all Intel mobo 850mvr Xp pro 1gig ram bus system runs protools that's it!
Any Clues!!!!!!
Phil Plaskon [img]images/icons/grin.gif[/img]
www.tenkproductions.com
Old 01-31-2003, 07:31 AM
Henning Z. Mortensen Henning Z. Mortensen is offline
Default Re: Pencil Tool Problem
I had the same problem. Digi says it (maybe) happens if you have 1GB or more ram.
Try setting the Paging File Initial Size to 1065 or lower in
Virtual Memory. 1024 is the recommended value.
To set this, go to:
SystemProperties>Advanced>Performance>Settings>Adv anced>Virtual Memory>Change
I put 1024 in init. and max. - and it works fine here
Old 01-31-2003, 11:48 AM
Rail Jon Rogut Rail Jon Rogut is offline
If you select around the area and consolidate it before using the pencil.. does that work? There was a similar thread recently on the Mac side where this can happen when you have imported (via OMF) files.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-31-2003, 07:55 PM
Thanks Guy's
I found that post in the answer base about the 1 gig of ram.I removed 512 so I have 512 in the system and restarted launched protools opened a session and used the pencil tool.It works fine now Who Knew! [img]images/icons/grin.gif[/img]
Phil Plaskon
Free Hand Pencil Tool Becomes Line Pencil Tool Vogger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-27-2009 10:23 PM
problem with pencil tool while trying to fix a wav rastayan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2003 01:55 AM
problem with pencil tool DrakeGiles Pro Tools TDM Systems (Mac) 7 09-18-2002 09:17 PM
problem with pencil tool DrakeGiles Pro Tools TDM Systems (Mac) 2 09-17-2002 09:18 AM
Pencil tool for digital pop problem dkrausz General Discussion 8 04-15-2002 11:08 AM
