Old 07-07-2007, 08:47 AM
figment figment is offline
Default monitoring Mic signal during playback.
Hey, I was wondering if anyone knows of a way to monitor the signal coming into the microphone during the playback of a session.
I have PTLE 7.2 cs10.
I can record just fine, and I can monitor the signal when the track is armed, but when I try to play the session to audition the vocals, I get no signal from the Mic until I stop the session.
If there was a way to do this, it would be very handy for me, and I am puzzled why I'm having this problem, as I don't remember coming across it before.
Hopefully, I am not missing something. But that's what this forum is for, right ;-)
thanks
figment
Digi002/ PTLE 7.3.1cs3/ XP Pro SP2/ Dual Core AMD Athlon 4400+ 2.2GHz 64 bit/ D-FI 939 board/ NVIDIA nForce4 Chipset/ 2GB DDR RAM/ Yamaha Motif ES88
Old 07-07-2007, 09:40 AM
spkguitar's Avatar
Default Re: monitoring Mic signal during playback.
alt + k
Old 07-07-2007, 11:19 AM
Isn't that the shortcut key for low latency monitoring?
I tried that, but if I have low latency monitoring enabled, then it won't let me use any plugs on my vox track, right?
I was hoping to be able to experiment with some vocal effects during playback, before I recorded the vocals.
Old 07-07-2007, 11:28 AM
spkguitar's Avatar
No. "Alt + k" is the shortcut key for toggling the Monitor Mode.
If you have it in "Input Only" mode, you monitor (not surprisingly from the name) only the input of the record enabled track. If you have it in "Auto Input" mode (which I think is your case) then you monitor what's actually on the track during playback, and then the input during recording ("auto"matically switching between).
If you need to monitor the input continuously, no matter what monitoring mode you are in, you should use an aux track for the input, and then create a send from the aux through a bus to a record enabled audio track while in "Auto Input" monitoring mode.
Old 07-07-2007, 12:11 PM
You know what- That makes sense. I thank you. You are a gentleman and a scholar.
Old 07-08-2007, 07:58 PM
3JDamon 3JDamon is offline
I still prefer using an outboard mixer for monitoring, and I leave the tracks muted when recording. I sometimes use pre-fader auxes to send the signal being recorded to reverbs, I recall that doesn't work in monitor mode, either you get the delayed signal or you disable all effects and sends. Reverbs don't suffer much from latency. I'm also not keen on the idea of using an interface channel for talkback. Mixers suitable for those tasks are under $100, and they have uses elsewhere.
Recording Dry Signal / Monitoring With Reverb frank1985 Eleven Rack 1 05-13-2013 03:56 PM
No Mic Signal and very low playback signal mbitanga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2011 07:44 AM
monitoring Mic signal during playback. figment 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-07-2007 08:49 AM
monitoring the audio signal from MIDI device mnbmusic MIDI 1 10-27-2005 06:41 AM
splitting signal for monitoring + recording davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 01-27-2003 09:51 AM
