Help... "Super Cue" punch in mode for Pro Tools? Can you do it?
I occasionally get the artist who wants to hear their voice the whole time while they are punching in. So in other words, they want to hear their voice along with the original voice and then when I punch them in, the other voice should mute.
It seems simple, but I can't figure out how to set this up. I thought that maybe you could have a track that has input monitoring on with the same input as the track that you are punching in (without input monitoring on). But when you punch in, their voice is louder because you now have the signal coming through twice. Any cool ideas of how to do this?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio Last edited by Dizzi45Z; 08-04-2011 at 08:52 PM. Reason: Rename post so people would find it easier. |
Re: Weird way of punching in help...
I've tried several ways to do this and nothing really worked. like most people i pull the recorded info onto a dedicated playback track but then you have to edit what you don't need before recording again. I did send an email to Steve Massey to see if he could modify his talk-back plugin to mute when PT goes into record then it could be used on a monitor track!! It must be doable, i'm surprised AviDigi haven't thought of this option. Chris
Hi! This is not sooo weird, I think this is known as the "super cue" feature of the SSL4000, so I think your console needs to support this. I don't know how it can be realized just within Pro Tools...
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave |
I'm not sitting in front of my PT-rig ... but wouldn't it work like this ? 1) Create a mono Aux input. 2) Choose as input the one which is coming from the vocalist's mic preamp. 3) Choose as output a mono bus and as a second (and maybe third) output (with ctrl key pressed) an output or bus which will feed your control room section & the headphone cue. 4) Route the bus (the one output from the Aux) over to the Audio Channel's input where you want to record the vocalist. That way, the vocalist/artist will always hear what's already recorded and he can sing in addition to it. As soon as you punch in (punch on the fly), he will only hear what he (or she) is singing. I never tried that so far, but I will do so tomorrow to see if this might work
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
The way you describe has the same problem as just making both an aux input and a regular audio track's input the same.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Good idea. Is his Talkback plug-in still compatible? I stopped using it because I thought that it became incompatible. In any case, I miss that plug-in. I would really find it useful if he did include that option as well.
Still using it in the latest PT version. Chris
looking for the installer for weeks...
Selling: |
1. If using a control surface you could punch n mute together (Mute Mic-Monitor feed).
2. You could set up a phase reversed mono (Mic-Monitor) so they cancel when punched.* * may require TDM-Trim Bothe channels and Delay Comp on (?). Figure the level balance for cancelation. |
I tried phase reversal but i couldn't get it to work. might try again though. Have you done it successfully? Chris
Help with punching in ~ PT 8 | maitredebas | Pro Tools M-Powered (Win) | 2 | 01-10-2009 08:00 PM |
Punching In | Jason Moon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-01-2005 05:10 AM |
punching in | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-02-2004 07:31 AM |
punching in | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-24-2004 05:22 PM |
MBox help - punching in w/o punching. | guitthefunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-12-2003 06:32 PM |
