Old 02-21-2011, 01:06 PM
dl0banter dl0banter is offline
Default Strike doesn't play back was was exported as MIDI??!?
I have an M-Audio 88 key MIDI controller hooked up through an MBox to PT 8.0 LE... I have the expansion pack for the instruments.
When I export MIDI from Strike, I can drag the MIDI that is generated over to the instrument track and it is there plain as day. When I do a playback it either doesn't play anything back or it plays something that I didn't export.
How do you get this thing to simply play back the midi that is in the track instead of whatever it feels like? This seems overly difficult for something that should be entirely intuitive???
Thanks,
D
Old 02-21-2011, 01:24 PM
Default Re: Strike doesn't play back was was exported as MIDI??!?
Thanks for anyone reading this stuff...
I figured it out... I am learning this stuff straight away and brand new to everything to its a little confusing...
Thanks,
D
Old 08-21-2014, 10:42 AM
Stringvester Stringvester is offline
Hi, I'm having the same problem - could you share how you worked it out.
Many thanks.
Old 08-21-2014, 11:55 AM
Southsidemusic's Avatar
Hi and welcome to the Community
As this thread died 3 years ago please start a new thread in the Virtual Instrument section and describe your exact issue aswell as all the info needed for us to help.
Read this before posting:
http://duc.avid.com/showthread.php?t=300050
Best Regards
Christopher
Many thanks.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Midi is played on time but midi notes are early on play back. steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-30-2022 12:17 PM
Midi Will Not Play Back ImIn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-08-2010 06:33 AM
QT7 won't play MIDI-1 files exported by PT7! EricWillhelm MIDI 9 04-12-2006 01:37 PM
Everything is MIDI up but no play back on the Aux Jerm87112 MIDI 1 05-22-2001 07:52 AM
midi doesn't play back right sleshnyc General Discussion 2 05-24-2000 05:41 PM
