Squashing Recycle Exported Midi Files
So I'm using Recycle to rebuild my kick track instead of Sound Replacer. I'm exporting the midi from within Recycle. I import it into PT's and as a Reason user would suspect, they're is an individual midi note for each slice of the Rex File.
My question to you is, is there a way to grab a large number of midi notes, regardless of what pitch values they may have, and send them to a specified pitch? Thanks... |
Re: Squashing Recycle Exported Midi Files
Hmmm, If im not mistaken, you can select all MIDI notes, drag them all to the top-most or bottom-most level of the MIDI window, and this will put them all on the furthermost note, then you can transpose them after that.
I think...anyway. I know for a fact this trick works with different velocities on Midi notes... hopefulyl iwth notes too
Ill suffer winter alone; ten thousand miles from home... |
I tried something like that last night but it took way too long to do.
I will revisit the process here soon to see if I can find a better method. I'll also be looking at throwin the midi to track in Reason and see if I can manipulate it there. Would groove templates extract the midi data necessary for a kick? Velocity, Rhythm (note placement/duration), etc... |
This sucks!!!!!
I thought Recycle would export a midi file that held velocity data. So let down... |
PPQ of MIDI files exported from Pro Tools | John_Toolbox | MIDI | 16 | 03-03-2011 06:13 AM |
extra stuff in my exported midi files??? | weezerboy | MIDI | 0 | 05-04-2007 10:57 AM |
"POP" at End of Exported Files? | Styles Bitchly | Pro Tools TDM Systems (Mac) | 1 | 05-25-2006 08:16 PM |
QT7 won't play MIDI-1 files exported by PT7! | EricWillhelm | MIDI | 9 | 04-12-2006 01:37 PM |
Mp3 Exported Files | terraform | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-06-2002 04:51 AM |
