#81
Re: how to avoid clipping on post fader bus sends?
What you fail to grasp is that people here are defending "good" recording and mixing principles, and solid digital recording facts. That is no way means that everyone uses them... and some that don't can still end up with good results. Daves session is still an "ugly" thing to look at... but the bottom line is how does it sound. And based on how into continual learning he seems to be, he would probably learn some good stuff by reading this thread. It certainly wouldn't hurt. ff |
#82
It takes a lot of bad will to misunderstand another person so much... It's funny and sad at the same time. How can you even say that I am failing to grasp anything? I never tried to justify clipping. I pointed out a design flaw in Pro Tools HD where you can clip post fader send even if the rest of the signal path stays clean with no clipping. I agreed that I do things wrong way.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
#83
If all your tracks are always given to you that hot, why not simply calibrate the meters in ProTools to something more fitting for you?
Such as -24dBFs = 0VU ? This way, the hot signal that you do not mind the sound of at +20dBv will show -4dBFs in your metering and you can keep the faders in the range you want. Then when you want to push things for whatever reasons near or into clipping you can do so. It seems to me this is a visual thing for you. Digital Meters mean NOTHING unless you know the point of reference to an actual level such as 0VU. But you aren't interested in the meters giving you numerical information - You just want to SEE them in more detail (?) as this helps your mixing. Isn't that the easiest solution? This will also increase your headroom if you do any recording as well. Maybe its too simple so Im missing something huge here as to why this hasn'y been mentioned yet since the OP is all about comfort of physical faders and meter heights (and how achieving that comfort causes PF clipping) Maybe? EDIT: I guess the problem with this is that the audio is already recorded at near full scale 24-bit. So playing back a looooong single bass note that was recorded at +20dBv will show a steady reading of -4dBFs on a -24dBfs=0VU cal'd system. If you push that fader up 3dB more, will it distort in sound but not hit the red yet? To be even clearer -- What if you cal to -30?? A +20dBv sound will read as -10fs , but that audio file doesn't have 10 more dB of headroom right?
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• Last edited by Mt.Everest; 06-18-2011 at 12:01 AM. Reason: Confused |
#84
- Eric |
#85
Try this: duplicate the offending track, remove its output from the main mix, insert send post-fader on the duplicated track and adjust levels accordingly. This would leave your levels untouched on the original track.
Also, check this neat calculator online for dbV, dbu to actual volts conversion, since all computer mixes have to get converted to speakers at some point, last time I checked my eyes can't hear. http://www.sengpielaudio.com/calculator-db-volt.htm Engineers constantly calibrate, monitor and meter equipment. No equipment is without limits. Beyond faulty defect, users should accept these limits or purchase/build the proper equipment. I have a hammer, I use it to hit nails and stuff. It can also hit my thumb. When that happens, I calibrate properly to ensure it does not happen again. Same concept, although I doubt calibration would have come second if I had a nail gun. Last edited by musicsmith; 06-19-2011 at 11:02 PM. Reason: add link |
#86
Automating Pre/Post Fader Sends | Matthew Harrold | Post - Surround - Video | 8 | 11-27-2017 06:33 PM |
Clipping of post fader sends in 6.4 | burningbusch | Pro Tools TDM Systems (Mac) | 4 | 06-07-2011 08:01 AM |
SENDS: Post/Pre-Fader which is better/most common? | GapeOne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-24-2004 03:04 PM |
Sends, pre-post fader? | Tito Ricci Arballo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-22-2003 06:16 PM |
Pre/Post fader aux sends not automated?!? | DannyVanSpreuwel | Pro Tools TDM Systems (Mac) | 2 | 11-29-2000 10:45 AM |
