Old 11-08-2010, 02:47 PM
francois.fab francois.fab is offline
Default Command 8 under Win7 32b with PTLE8.0.4cs2
Hello,
My Command8 does not work with PT8.0.4cs2. I am running 32bit Win7. Before I used the same computer with XP, I had no problem. The screen displays Command8: offline. If I touch faders, PT answered, but PT does not send information Command8. In Setup / Peripherals / Midi Controllers, Type I Command8 / receive from: Command8 / Send to: Command8 emulated / Ch 8.
Thank you for your help.
Old 11-16-2010, 01:05 PM
Dot Dot is offline
Default Re: Command 8 under Win7 32b with PTLE8.0.4cs2
run pt8 as administrator. had same issue, but this solved my problem. win7 64
Old 12-05-2010, 12:37 PM
ttrroonn ttrroonn is offline
Thanx Dot. I have been wresting with this problem for months. I thought that since I was logged on as administrator that programs ran as administrator automatically. Not so Run Pro tools from the start menu as an administrator solved all my command 8 recognition problems.
Concerns moving from PTLe8 XP to PT10 Win7 rems Windows 6 03-23-2012 07:06 PM
first mac pro to ptle8.3 redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-14-2011 08:12 AM
Command|8 trouble with Win7 x64 & PTLE 8.0.3 ynor ProControl, Control|24, Command|8 5 09-04-2011 01:02 PM
Problem with Command|8 on PT8.1 HD1 Win7 64 ynor Pro Tools TDM Systems (Win) 2 01-04-2011 09:55 PM
PTLE8 and Mac Pro? kastadyne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-24-2008 10:03 AM
