Pro Tools MP 7.4.2 hanging on "Locaating Audio Files"
This just started happening to me. It only happens in the following circumstance:
1. I open Pro Tools MP 7.4.2 2. I open a Session 3. Close session 4. Try to open another Locating Audio Files. And the system hangs. It never hangs on the first one. Then I have to Force Quit because PTMP stops responding. I've tried trashing the prefs and database files, and a different firewire cable. This just started happening. I don't think anything changed since it was working fine recently. It's on my home system which is listed in my signature. (I also posted this to a similar thread under Pro Tools HD, but since it's an MP issue, I wanted to post it here too.)
Home: 27" iMac, (Retina 5k, 2017) 4.2GHz Intel Core i7, 32 GB RAM OSX 10.3.3 UAD Apollo 8 Duo UAD Apollo 16 silverface UAD Satellite Octo, Thunderbolt PT 2018.10 Work: Mac Pro (Mid 2012) 2x3.06GHz 6-Core Xeon, 32 GB 1333 MHz DDR3 OSX 10.13.6 Avid HDX HD Madi x 3 SSL C100 |
Re: Pro Tools MP 7.4.2 hanging on "Locaating Audio Files"
Bump... Digi?
One week later?
So I take it by the lack of responses, no else has this problem, and Digi's never seen it?
If you want a guaranteed response from us, you need to submit a support request via the Tech Support Request Form, per the instructions in the Help Us Help You sticky at the top of every forum.
Now, as far as your problem goes - I'm assuming this is occurring with your home system, yes? Have you tried moving a couple sessions to the internal drive, disconnecting the FW drive and testing again? It may be a problem with that FW drive. Also, how do you have it and the ProjectMix connected to the computer, exactly? Have you done any other troubleshooting besides trashing prefs and databases? |
Thanks for getting back to me...
I'll try in the internal drive idea. I've swapped out some cables, and gone through the general troubleshooting sticky as well. My configuration is as follows: iMac > FW Drive > PMIO. I'll have to check on the 800/400 stuff to see where I have them actually connected.
Pro Tools 7.4.2 hanging on "locating audio files" | thenewnoise | Pro Tools TDM Systems (Mac) | 11 | 12-04-2009 06:25 AM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
Deleting files in "Audio Files" folder on purpose... | Qrackaduck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-04-2009 01:01 PM |
Structure - what does "Monolithic" mean as it pertains to "part" files? | Jared_TL | Virtual Instruments | 2 | 12-07-2008 03:37 AM |
System freezing "hanging" up all the time! | postman56 | Pro Tools TDM Systems (Mac) | 2 | 09-15-2008 01:59 PM |
