Velvet \"Content not Found\" on OS X
Hi!
I'm having problems with Velvet, it keeps telling me that "Content not found" - I suspect is related with previously moving my Home folder to another partition:
The hard disk partition scheme:
When I installed Velvet + the update, the Velvet data lib was installed on the default location - that would be on "(partition A)/Applications/Digidesign/Velvet". Didn't work. Then I ran the "Set Content Location" script - didn't work. Then I moved the folder to "(Partition B)/Audio/Libraries/Digidesign AIR/Velvet" and ran the Set Location script and it still doesn't work. At this point I stopped trying and started to weep :P The OS X Console doesn't give me that much info whenever it fails to load content... unless I'm overlooking something. Any ideas on how to fix this??? (or where to look at???)
= Vov =
Re: Velvet \"Content not Found\" on OS X
This version of Velvet wont work with 7.4.2. You are going to have t wait until mid-July according to Digidesign for the version that does. I found this out the hard way too!
Oh my! Now is a good time to start crying...
So that's why it doesn't work then? Where could I stay tuned for the update status???
= Vov =
Updated Velvet for Leopard... the problem is still there
OK I waited for the Leopard update for Velvet.
I've just installed it... and I still the same problem. Help! |
If you are able to return your home folder to it's original location and re-run the "Set Content Location" from where you have your "Velvet Data.big" file it should be able to set the preferred location for the Velvet Data. |
Help Needed - Velvet in PT10, content gone!! | brotherjohn | Virtual Instruments | 1 | 04-25-2013 02:53 PM |
PT8 Factory Content not found | guitar486 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 28 | 10-01-2010 05:51 AM |
Factory Content not Found??? | teacherman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-29-2010 08:33 AM |
Velvet & Strike: Content Not Found error | thopman | Virtual Instruments | 13 | 07-20-2009 06:14 PM |
AIR "Content Not Found" after upgrade | gdugan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-10-2008 07:42 AM |
